7-21-2021
Discussion in 'Changelog' started by robregen, Jul 21, 2021.
    * Updated combat range based on decompile from client.
    * Moved combat range calcs from z offset, to bounding model radius for all models through luclin.
    * Reverted part of patch which started the quick timeouts happening at character select. This may or may not have an affect on the timeouts.
    * Added a pathing fix.
    * fixed elevator that get stuck with no close timer (Pok Elevator).
    * magelo web stats export - unbuffed HP calculation tweak
    * Amulet of the Void should now be able to recharge using box of the void.
    * sebilis: Added a missing NPC patrol route.
    Pathing:
    * Fixed some bad pathing nodes areas in Sebilis down by Juggs and Trakanon.
    showstring, Lyrina, pivoo and 2 others like this.
  2. pivoo
    pivoo People Like Me
    Looks like something is wrong with AEGO buff. My lvl 19 characters were losing 80% of HP in a second while doing nothing. I Unticked AEGO buff but HP drop happened again. The third character, without any buffs was not affected. I quickly logged out before I die. Was happening in Paludial Caverns (probably not important)
  3. robregen
    I'll do a hotfix to patch that bug
    pivoo likes this.
  4. robregen
    HOTFIX Code:
    * fix max hp calc i messed up in previous commit
    pivoo, Lyrina, Korya and 1 other person like this.
  5. showstring
    May need to hotfix to rollback the hitbox change.
  6. showstring
    Just confirming this now appears to be fixed.
    THANK YOU SO MUCH @Haynar !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    This has significantly improved my play experience
  7. Radda
    Radda People Like Me
    is this what's causing mobs to hit me from a range they shouldnt?
    unable to bard currently.
  8. Haynar
    Yep. Some models need some adjustments based on their size. Need to work out the calcs. And will start with ones that are most off.
    I thought bards just sing mana song?
    Mechaike and Mokli like this.
  9. Haynar
    Fixed the missing scaling factor for combat range calcs, should be in next patch.
    This fixes the wolves. But avoid the bats. Their very large size will now make them unable to be swarmed by bard. The size corrections made their combat range even larger.
    Mechaike and thucydides like this.
  10. Haynar
    A few races are messed up. Like bats. They dont follow typical models for combat range calcs. I am parsing more stuff on live for what looks like outliers. So should have those cleaned up before patch.
  11. Sketchy
    We can't stop here, this is bat country!
    sowislifesowislove and Mokli like this.
  12. Radda
    good thing bats are everywhere and spawn randomly from traps.
  13. Radda
    are bats expected to be fixxed or no?
    confusion due to your double post.
    "But avoid the bats. Their very large size will now make them unable to be swarmed by bard. The size corrections made their combat range even larger."
    and
    "Like bats. They dont follow typical models for combat range calcs. I am parsing more stuff on live for what looks like outliers. So should have those cleaned up before patch"
  14. Haynar
    It will drive you batty just thinking about it.
    I took more data, we are several iterations later in getting this working right. Bats should be back on the menu.
  15. thucydides
    Haynar you are on a roll!
    Mechaike likes this.
  16. showstring
    holy moly, Haynar deserves all the tips!
