Newb Question on 3 box here
Discussion in 'General Discussion' started by Dathark, Jan 7, 2020.
Tags:
  1. Dathark
    Dathark New Member
    Are any programs such as is Boxer allowed here if so what is best program or what do you use to assist you in 3 boxing if not thanks for answering...
  2. Dathark
    Dathark New Member
    Any help on most efficient way to 3 box legally here ??
  3. showstring
    People utilise Hotkey.net which is included in the client, as per: http://wiki.takp.info/index.php?title=Getting_Started#Switching_Client_Windows_with_HotKeyNet
    Multi-boxing on this server simply means you can run multiple clients, which you switch to manually and input each command in manually while looking at the active window. All Hotkey.net does is switch the active client window if you run them all on one computer. You can use multiple computers if you prefer.
    I don't think ISBoxer is permitted or other similar programs (I assume you're referring to ISBoxer).
    Be mindful sending any commands to non-active background windows is not permitted.
    Make sure you familiarize yourself with server rules https://www.takproject.net/forums/index.php?threads/rules-101.7/
    Ripwind likes this.
  4. Dathark
    Dathark New Member
    Thank You for the Help..
