8-30-2023
Discussion in 'Changelog' started by robregen, Aug 30, 2023.
    * adjusted inventory logic for items being equipped into worn slots to account for some ranged items that don't explicitly have RANGE/AMMO slot but still should work for throwing
    * try to fix corpses sometimes disappearing on server restarts
    * adjust a required level check for some clicky items
    * najena: Many small adjustments to NPCs in the zone including level variance, spawn variance, aggro radii, see invisible chance, charm immunity.
    * najena: Added new NPC 'a minotaur' and combined goblin spawn points.
    * najena: Cleaned up all drop tables.
    * sebilis: 'a fallen monk master' renamed to 'a fallen iksar master'.
    * sebilis: 'sebilite golem' level range is now 48-52 instead of always 51.
    * sebilis: New NPC type 'a Sebilite golem' which replaces the lowercase version in the West wing.
    * befallen: New NPC type a female gnome 'a necro apprentice'.
    * befallen: Cleaned up some of the drop tables.
    * highpass: Gnoll respawn is now 2 minutes faster.
    * Cleaned up minotaur NPC drop tables in several zones.
    * Fixed shark pathing near ancient cyclops in oot
    * Added 7 missing guards to nektulos (6 are bridge guards, 1 gate guard)
    * Added missing "CWS Model SX" to solusek A
    * Fixed up Bandits/Raiders in West Karana, North Karana, East Karana, South Karana, Lake Rathe, and Rathe Mountains. Their spawn rate and drops are more precise. Human bandits will spawn much more often (60%+) and drop sashes a bit more often (40% from previous 35%). Humans are also the best source of bronze weapons.
    * Fixed bugged roamer at Unrest entrance
    * Jracol Brestiage in qeynos2 is now a night spawn
    * Added day/night cycle to most roaming undead in lfaydark and added missing npc "a mist wolf" as their day spawn counterpart
    * Added 3 missing race/gender variants of the smugglers/thugs in qcat
    * Added missing "an orc priest" to lake rathetear
    * Fixed up all "a froglok tad" loot tables
    * Added missing "a mangy rat" to misty
    Script
    * Added a pathing node and interaction between Zyle and Euboea on the sister island in OOT, Zyle will now agro near the docks on sister island if he's nearby
    * Added missing hail text to about 10 npc's in skyshrine and fixed a couple other hail dialogues
    * Added "Tattered Parchment" to Bunk Odon in Rathe Mountains, used in follow-up Noble's Crest quest. Final quest is broken this era as it requires drops from merchant npcs that poof when you kill them (and were unkillable on live until 2019).
    MISC
    * regenerate South Ro and Innothule Map file so players will no longer be port under the portal object.
    Tuluvien, Frosst, Mascha and 3 others like this.
  2. Darchon
    Which clickies to which levels by chance?
  3. solar
    Hmm quite a few, like Crystallized Pumice and Summoned: Talisman of Return.. things that were interrupting and giving this message: Error: level not high enough. Hopefully these work now.
    Ravenwing likes this.
  4. Elroz
    summon fangs clicky from ssra too, i think
