Highlight: *** Plane of Sky is now open *** - see below for the list of changes. Code: https://github.com/EQMacEmu/Server/compare/a31472d078a8...2a1c4c9067e3 Cavedude * Possible spell crash fix. * Added some missing newzone columns related to music. (SQL already added to TAK database and populated using AK newzone packets.) * Added inventory logging when Bards loot any combination of primary weapons and secondary instruments. * Fixed an issue where small ranged items were not auto looting into the ammo slot if available. Robregen * Added a boolean rule to use on all NPC level 18+ and undead to aggro regardless of level, setting this rule to true will disabled the previously aggro rule dependent on intellect. * Added a column to NPC_Type table for an exemption on certain NPC to aggro under level 18 such as a bixie drone. Database: Robregen * set intellent value equal to wisdom value on all NPC level 18+ and undead that were previously used for aggro intellect rule. * Added Lich of Miragul in Everfrost. * There should always be a Minimun of 7 wooly mammath spawns in Everfrost. * Correct the spawnpoint of Webclaw Murkwave / PH and added in its pathing in Lake Rathe. * Added a level 30-32 Giant Skeleton which only carries "Ingot of Sacrament" as rare spawn in Rathe Mountain. * Tani N Marr should be spawning / despawning at the correct time. * Oggok Guards will no longer hit hard. * There will always be a minimum of 7 Hills Giants in Rathe mountains. up to 11 maximum. * Iksar broodling should now have a chance to spawn on Golem's death in Plane of Fear. * Fixed the Peacekeeper Faction to not be KOS to half elves. * Raine Beteria should now be on Craftkeeper faction * Fixed the stacking issue for Black tome of silver runes. * Removed the charges from the following items: Decaying finger bones, Decaying Ulna, Decaying Tibia, and Decaying Foot bones. * Added the following missing NPC in Field of Bones: Iksar Dakoit, Carrion Queen, a burynai sapper, a burynai cutter. * Remove the cosmetic weapon from "a skeleton" in Qeynos Hills. * increase the drop rate for Glowing Black Stone from Pyzjin as well as lowing her spawn chance. General: Robregen * Redo Highkeep path file Changelog for Plane of Sky: Torven * hitpoints, damages, attack delays, resist values, spell sets, aggro+assist radii, immunity flags set for airplane isle 5 * Damages, attack delays, resist values, spell sets set for airplane NPCs on isles 6, 7, 8 * Spawn point for boss bee chain moved to center spawn point on airplane isle 6 Robregen * Added pathings and event scripts for all island NPCs that were already implemented by Robregen on PEQ. * adjusted loots. * fixed various quests. * added the following reward items to database: Thelvorn, Blade of Light, Thornstinger, and Khyldorn the Blood Drinker. * Implemented removing of keys when zoning out. Keys will still be retained if logging out or leaving it on corpse in Plane of Sky. * Fixed the buff strips on zone in.
