6-27-2018
Discussion in 'Changelog' started by robregen, Jun 27, 2018.
    * Updated some UCS timings.
    * Added additional CPU optimizations.
    * Added a message for keys being added to the keyring.
    * More mob falling below world fixes.
    * Archery should no longer be riposted by Enraged NPCs.
    * The IMMUNE_RIPOSTE special ability looked like it was coded incorrectly, so I changed it.
    * Riposte code refactored a tiny bit.
    solar
    * Theft of Thought can no longer fizzle when attempting to cast on a non-caster mob, it's interrupted prior to the fizzle check.
    * Mind Wrack, Wandering Mind and Scryer's Trespass act as mana-tap-over-time spells and can no longer be cast or procced on non-casters.
    * Fixed a bug that caused some queued tells to be lost while zoning
    * Added a missing recipe: Seafood Platter (was in the previous patch)
    * correct the spelling for the Greta_Terrilon.lua questsay.
    Linkamus and Elrontaur like this.
  2. Tyrion
    Tyrion Well-Known Member
    Mobs in chardok at least will only stay above the surface of water and can't be cast on or pulled down.
  3. Haynar
    Can you be more specific where in Chardok? It will be a few hours before I can look at it.
  4. Tyrion
    Pulled collaborator to water in front of alchemist/herbalist house.
  5. Darchon
    I'd suggest EQAtlas #s or locations. Not everyone is familiar with the layout of that awful zone.
  6. Tyrion
    So all the water on the Y axis of 0-100 on map.
  7. Neealana
    Scryer's Trespass ? Will this be available to us ? !
  8. Faults
    FIFY
  9. Haynar
    I should break charm for first month or two of Luclin. Just to make it interesting.
  10. solar
    Scryer's Trespass is in the database and I checked every spell that was affected by the code change. I think that one is LoY era so it won't be obtainable on TAKP.
  11. Slayzz
    You probably already tried this but I noticed that would happen when I was killing in that same spot and the mobs would float over head while charmed if i didn’t move but if i moved the mob would then submerge underwater. It was as though it got stuck directly overhead but once u move around the mob drops down
  12. Slayzz
    It’s the best spot there is to pull and kill there. Can pull like every PH in the zone to that spot and not have to move :)
    At least the good ones
  13. Tyrion
    Yep tried moving all over even after charm wore off he just beat my ass but wouldn’t get his scales wet.
  14. Bum
    I tried to zone in to metherbian lair and it didn't work. Can I get a refund on my Luclin purchase?
  15. Haynar
    Sure. Just deleted all ur plat. Consider it ur refund.
    XOXOXO
    Linkamus, Bum and Slayzz like this.
  16. showstring
    Karnors castle area where the drolvarg warlord spawns -> trying to pull mobs down the stairs they go half way down the stairs, disappear under the world, the pop up from behind you from the drolvarg warlord room.
    Also fighting mobs on the stairs, just says "you cannot see your target from here" but it appears above the world, and is happily meeling you etc, but you can't cast on them.
    loc of problematic spot is +56, -567, +34
  17. showstring
    The cleric guildmaster in Felwithe - Yeolarn Brozneleaf - has also gained an amazing ability to chase you from under the world and backstab you
  18. showstring
    sorry that was a brutal *bash not a backstab, not quite that elite
    either way, thought i got away, was casting a heal, and whacked me from under the world somewhere
    sad days :(
  19. Linkamus
    Oh man, that is evil...
  20. Haynar
    KC pathing needs work. Will put it on my list. Found multiple issues. Will take some time to sort out.
    pharmakos, Dane and Slayzz like this.
  21. Haynar
    But is it?
  22. Ravenwing
    "Charm" is a curious way to spell "color stuns"!
    Dane likes this.
  23. Haynar
    That would be giving mobs sunglasses. Their future is bright.
