2-4-2015
Discussion in 'Changelog' started by robregen, Feb 4, 2015.
    Highlight
    * Nagafen and Vox should now be ready to be killed.
    * Merged massive overhaul Logging system from EQEmu see http://wiki.eqemulator.org/p?Logging_System_Overhaul&frm=Main (Credit to Akkadius)
    * Added the Item Looting rewrites from KLS loots branch. Looting overall should be more effective across all zones. (Credit to KLS)
    * Corpses will no longer be rezzable after their rez timer expires. Required SQL: utils\sql\git\required\2015_01_31_rezzable.sql
    * Corrected rez timer message and failure message based on AK logs.
    * Fixed lua function eq.attack and eq.signal
    * Cleaned up food consumption, forage, and IsDesertZone a bit.
    * merge packet logging system from EQEmu (credit to Akkadius)
    * Altered server to client packet logging to use our netcode.
    * Experimental Z coord change to CheckLosFN to hopefully correct the Dragon AE issue.
    * Added BestZ calculation to combat push.
    * ResistSpell() cleanup, pac fix, deep red con bonus
    * Dragon AoE partials, lifetap partials, skill type 52 fix
    * Fixed LInara Parlone Loottable in Najena
    * Added missing loots to Paineel Guards
    * Fixed the item Typo O'range' Headband to Orange Headband
    * Added missing loots to Reanimated Hand in Unrest.
    * added the paladin default spellset to Quid Rilstone of Rathe Mountain.
    * Added missing loots to Freeport Guards.
    * Fixed the z-coordinate for Glyphed Guard near Graveyard in Mistmoore.
    * Reoganized loots in separate tables for The Ishva Mal in Paws.
    * added the small ringmail armor sets to a crazed goblin's loottable in Butcherblock.
    Torvan
    * default druid spell set: put a 45 second recast delay on sunbeam.
    * default druid spell set: removed chloroplast.
    * mistmoore: a cloaked dhampyre's spawn rate increased to 20%, up from 10%.
    * mistmoore: a cloaked dhampyre's cloak drop rate decreased to 25%, down from 30%.
    * kedge: Phinigel Autropos's loot table adjusted to be more in-line with magelo data and allakhazam comments.
    * kedge: All NPCs flagged immune to flee and fear; cold resist increased.
    * soldungb: fire giants proximity aggro flagged.
    Speedz
    * disabled Equestrielle the Corrupted since it is quite out of era and devastating to traffic in zone.
    Scripts:
    * Fixed the Tesch Val Scroll turn in for Edvard Tommels of Qeynos.
    * Fixed the Staff of the Bloodsaber Quest turn in.
