I like the vert ui that came with the download a lot, but it doesn't seem to show mana bars. What am I missing? Thanks
The original Vert UI was made by a rogue or monk (I don't recall which) so it didn't have a mana bar. I actually put the spell book button in it myself before putting the UI into the archive otherwise it wouldn't have had that either.
Hmm. Can I get any other skins that would work? I tried a vert blue download from a uiskins site, but it didn't load. I haven't looked at the logs yet to see why.
I liked Power of Two myself. That comes with the supported client and was a favorite on AK. Old UIs found online will almost certainly require modifications for compatibility. Sony changed UI functionality from patch to patch, and our client is from a patch in-between PoP's launch and Ykesha's launch.
Vert Min has been converted. http://www.takproject.net/forums/index.php?threads/vert-minimum-ui.4655/
It came with a mana bar, its in the "extras" folder, replace the EQUI_PlayerWindow.xml in the main UI directory for vert with EQUI_PlayerWindow.xml.INT or EQUI_PlayerWindow.xml.WIS removing the ".INT" or ".WIS" from the end of the file name. I modded the XML myself before I saw these files. This is what mine looks like: Here is the link if you wanna try it in your copy of vert. https://www.dropbox.com/s/bi2ulpw9ntz3sqg/EQUI_PlayerWindow.xml?dl=1
