http://p99.yourfirefly.com/ High-res S3D files from EQ Trilogy install [info]: highres_s3d.zip (1.1G) High-res character textures [info] [screenshot]: x4classicUpgrade.zip (215M) Those files update the old titanium install files to better looking SOL files As you can see here:
Be sure to delete any .txc files in your everquest folder; they'll appear as Global_chr.wld.txc so the changes will stick. But here is the difference: Before After
It appears in some cases the old global files end up re-creating the txc files; to solve this I created a batch file to clear those out then start your instances Code: [ Only registered users can see the bbcode. Click Here To Register... ] Simply edit the drive locations to where your clients are held and save this code into a txt file (.bat) and run it from the desktop to clear all the old txc files and start the instances with the updated graphics every time.
