Trivial combine success rate?
Discussion in 'General Discussion' started by Domni, Aug 2, 2022.
  1. Domni
    Domni Well-Known Member
    Hi guys, I'm just wondering what the trivial combine success rate is supposed to be please? Is it constant or variable depending on the recipe and/or post trivial skill level? I'm asking because after 111 leather padding combines at 32 tailoring skill, I got a success rate of 70.27%, and I also failed 5x in a row (evidence below, apologies for the low contrast).
  2. Devour_Souls
  3. showstring
    "Trivial" does not mean 95% success rate.
  4. Darchon
    At low skill levels specifically, being higher skill than the trivial of the combine does not grant you maximum success chance. You have to skill up a ways beyond the trivial to reach that.
    This flips at the higher end. A person with maximum skill of 252 modified, can do combines up to 278 trivial and retain 95% success rate.
    In your case, 32 skill for 31 trivial combine the success rate is 67%. So with your 70% you beat the average. If you wanted to reach maximum success rate of 95%, you need a skill of 60, nearly double the trivial level.
    pivoo, showstring, Neealana and 3 others like this.
  5. Domni
    Thanks for all the replies, really appreciate the math Darchon
