I know HOW to alt tab on a mac, but i simply cannot get the client to: A) go into a "window" so that i can "alt-tab" between them, and B) use the mouse wheel to scroll into 3rd person.
this should go to Technical Support forums sounds like you need to activate windowed mode via the eqclient.ini file for A.) B.) mouse wheel scrolling behind your character is not supported in this client version
Shouldn't be a deal breaker. Just open up the eqclient.ini file under Library/Application Support/Everquest and add the line: WindowedMode=TRUE, and VOILA. Just add it below the top "default" line and you should be golden to tab through your programs
