Best Torpor Camp
Discussion in 'General Discussion' started by Slayzz, Dec 22, 2017.
  1. Slayzz
    So I am still in the market for Torpor but since I have had zero luck buying it, I might as well start gameplanning how to camp it.
    Wondering what the “best” camp is and what has the best drop rates. I’m pretty much eliminating the possibility of the WW dragons (Harla Dar etc), Gorenaire (no thank you), and Vaniki (MAJOR pita). I also eliminated VP as I am not keyed. So outside of those I have broken down the remaining camps/mobs and was hoping for a ranking on drop rate and difficulty or if anyone has feedback or suggestions and if they r REALISTICALLY 3 boxable Or not. I pulled the drop list straight from TAKP Allaclone.
    Talendor
    Severilous
    Overking
    Seb Protectors and Tolapmuj
    Emperor Chottal
    Guardian Wurm/Ancient Wyverns
    Thanks in advance!!!
  2. Fadetree
    I would think the Wurms/Wyverns would be best boxability, but I'm no expert.
  3. Cadsuane
    I used to solo the whole crypt/chottal area at 62. It would be "easiest" but probably not best due to him being an uncommon spawn
  4. Elroz
    I killed tola/prot maybe 30 times each when kunark was still fairly fresh and didn't get any torpors. I did get a bunch of other good spells, but their value is probably much lower now - that camp probably isn't worth the time involved.
  5. gardnerjens
    lava drakes in Vp
  6. 99problems
    99problems New Member
    If your able to kill Protector and Tola it will be your fastest way to the drop. Tola charms so be aware of that
  7. actualspaide
    Best is strong term. Although nukes right I think your highest drop rate will be the vp drakes. They are a bit unrealistic though probably, so you are really left with terrible options to box. I'd personally suggest getting a small crew of friends and getting kunark dragons on lock. You will get nice loot and probably quickest route to torpor
  8. Faults
    You will see far less emperor spawns than prot/tola. He won't be more than 1 every 2 hours.
  9. Randall
    Randall New Member
    I use to do the Guardian Wurms and Ancient Wyverns back in the day. Lots of valuable spell drops! Probably 1 in 100 for any given spell.
  10. Darchon
    VP farming is really the best way but doing that as a trio may be challenging.
  11. Videri-Tala
    Videri-Tala Well-Known Member
    Yikes, 3 VP keys.
    How difficult is it boxing in there? Can you Wake of Tranq and pull singles at the entrance?
  12. Darchon
    The issue is the varying difficulty in guardian wurms. Some hit for 300, some hit for 700, some hit for 1500. Some AE Vox/Nagafen DD AEs, some AE fear. Some will spawn another on their death, some will spawn two on their death.
    So a single 300 wurm is no problem. A 1500 wurm with AE fear hurts though.
    Videri-Tala likes this.
  13. Quath
    Quath Member
    Be the ultimate iron man. I'll even res you out when you die and need cr!
  14. actualspaide
    There are also worms that banish to ent
  15. Bum
    Wurms*
  16. Videri-Tala
    Does this variation apply only to the guardian wurms in VP, or to the ones outside in Skyfire as well?
  17. Bum
    outside are normal, only in VP do they vary
  18. nworbetan
    nworbetan Member
    There was a patch on the live servers on May 14, 2003 that drew my attention to Veeshan's Peak, and I spent a lot of time soloing in that zone over the next year until they did a much more serious revamp in 2004. I have no idea whether these tweaks happened on Al'Kabor though, and my gut instinct says they probably didn't. So this post and my memories might not be relevant at all on TAKP.
    The guardian wurms inside VP after this patch still spawned another on death sometimes, and spawning two on death seems pretty likely too, but from memory they never did more than 500 melee damage and didn't fear any more. I was a Vex Thal and Elemental Planes geared shaman at the time. I don't remember ever seeing Torpor drop, but I made quite a few clerics happy with copies of Divine Intervention.
  19. Foxhorde
    Foxhorde People Like Me
    Just noticed a lot of these mobs drop my emissary of Thule pet spell as well so if we can catch any of them up I’d be happy to try and help you kill them. I box
    Necro, chanter, cleric
