Code: * Temporary fix to troubleshoot Save(), if this helps fix some desync and save issues then Save() may need to be redone. - The intent is to see if this resolves any desync and massive rollbacks on LD. - Also wondering if this may help in figuring out login issues. - The thought behind that is, if there are any character pp vs other data save conflicts that might be causing hang ups in the login process. - Pretty sure this will have performance side effects that is why it is a temp fix. Web Page: * Fixed IP check logic, frozen accounts should not happen so often. * Magelo is available again in a limited capacity.
