Code: * Changed code to use slot 0 for cursor instead of slot 30. (cavedude - I've tested this out locally, but problems may still linger.) - This is the first step to hopefully fixing item desyncs. - Admins, run the following query: UPDATE inventory set slotid = 0 where slotid = 30; * Added a message to players warning them about zoning with a bag on their cursor containing items. - This can/will cause a desync, until we can figure out how to send these items to the client so it recognizes them. - (cavedude - I tried every opcode we have with no luck.) - This most likely is related to items in dropped bags and world containers not working either. * Removed some unneeded item code (shared banks, some remaining augment code.) * Flash of Light will now force an NPC to run (using fear pathing) if they are out of combat range. * Changed buffs being stripped on low HP to compare against HP from items, instead of from spells. * Removed some orphaned code and commented out some debug logging. Database: * Added Deputy_Eigon in Misty Thicket * The following NPC were Added for Highpass: - an_orc_mercenary, - an_orc_warrior, - an_orc_acolyte, - an_orc_berserker, - an_orc_conscript, - Vopuk_Shralok, - Recfek_Shralok, - Hagnis_Shralok, - a_gnoll_brawler, - a_gnoll_shaman, - a_gnoll_champion, - a_gnoll_flamepaw, - a_gnoll, - a_gnoll_soothsayer, - Grenix_Mucktail * Spawnpoints for Orcs were moved closer to zoneline. * Added a third and fourth orc spawnpoints. * Added a gnoll spawnpoint. * Added a path grid for Dyllin Starshine in HHP. Quest Scripts: Nothing at this time.
