Code: * When summoning a pet the server will pick the best focus item you have equipped for that pets level range * Support for PoP and Luclin Focus items that work for NEC, MAG, BST * Focus Items are semi hard coded in a constant array so they are easy to add / update * spell_effect file is cleaned up * Pet scaling should work more like it did on Al'kabor * Removed Modern Client Guild codes. * Changed player speed default rule. * Small tweaks to GM skill training. * Fixed the client crash when you receive a bag through quest and your inventory is full. (It will go to your cursor - which needs to be clear.) * Faction messages will now take base modifiers into account. Scripts: * More updates to A_Shady_Swashbuckler. All implemented types working. Research, Baking, Fletching, Jewelcraft, Tailoring, Tinkering. Also fixed some bugs from last commit. Implemented a global held logger for features. Buffs work, TL to bind works.
