Code: Cavedude * Corrected an issue causing damage shields to count towards XP added in the previous patch. * NPCs will act as if they have never been damaged before when a charm spell they are buffed with fades. This does not affect damage they do to other mobs while charmed. The owner of the pet will retain credit even after charm fades. * Corrected an issue that could potentially cause nobody to get credit for a NPC kill. * Adjusted the Feign Death skill to have a lower success chance at lower skill levels. * Sneak will no longer prevent quest say triggers from working. * Group exp split rewrite. Simplified the code and added comments and logging to make it easier to read. It is also less likely to cause issues due to counter variables with invalid values. The counter variables are now set in a single loop, instead of being set and then possibly changed later on. * Corrected an issue sometimes causing the split code to attempt to hand out exp, when nobody in the group qualified. * The server will no longer ignore /sit packets that occur after the spell is cast, but before Eye of Zomm takes control of the client. * Changed playeraction to use the animation enums instead of meaningless numbers. * Rain spells will now use the beacon's entityid in OP_Action instead of the caster's so the caster is no longer forced to stand to other players on each wave. * Some more tweaks to the Feign Death skill chance. * Reclaim Energy will now use the pet's current HP to help determine the percentage of mana that should be reclaimed. * Reclaim Energy now works with the Mage epic pet. * TGB spells will now hit the caster regardless of raid affiliation. * The server will no longer allow Foliage Shield to land on other groups/raids when TGB is used. Haynar * Fixed some hatelist management issues that resulted in no faction hits on some mobs during ring war 10. * Added a fix for picking up items off ground, to prevent item loss in certain situations. * Zoning with a bag on the cursor will now add the internal items to the character weight appropriately. * Fixed some memory leaks, potential leaks, and some general inconsistencies. * Added some fixes for potential world server crashes. Database: Robregen * Added server reset timer to HoT ToV drakes, Named Wurm in NToV, Angry Goblin, and HS boss.
Heh, yeah, fun bug. After the patch, my SK appears clothed as normal on his client, but other toons see him as naked except for his sword and board. Displayed hitpoints and AC think he's nekkid, but when he swings at stuff he pierces as though he has a weapon.
