3-25-2015
Discussion in 'Changelog' started by robregen, Mar 25, 2015.
    * Elementals should now display properly when using the client old model option.
    * skip_los zone NPCs made to see through walls
    * NPCs in zones with skip_los==true will now aggro and cast on players through walls.
    * NPCs in zones with skip_los==true will now buff friendly NPCs through
    walls.
    * NPCs in every zone will now cast heals on injured friendly NPCs through walls.
    * skip_los zone NPC yells for help made to ignore LoS
    * added missing Human cultural smithing (freeport) recipe as well fixing broken ones.
    * added a missing recipe for Forged Firebrand Long Sword.
    * fixed the Enchanted dwarven plate gloves recipe.
    * split up the Ogre guards and Elementals level range in Najena and place them in the appropiate spot.
    * Higher level mages in Najena will now aggro on players regardless of level like on live if they are kos.
    * changed the spawn chance for Nokta shaman in Upper guk to 70/30 from 80/20.
    * slightly increase the lootdrop chance for animal pelts in the Karana since they no longer drop 2x per npc.
    * removed 2x lootdrop for any kind of meats for most NPCs.
    * increase the size for the Tigers for the trigger spawn from Grim's Tiger Revenge Quest in Kithicor.
    * add pathing for Kobb in Kithicor.
    * fixed the spawn condition to trigger Guard Donlan and Guard McCluskey to path.
    * rearrange loots into the appropiate tables and added missing loots and Research table to the following zones.
    - Kithicor
    - North Ro
    - Steamfont
    - Lesser Faydark
    - Greater Faydark
    - Paineel
    - Toxualla Forest
    * changed the tiger trigger spawn location for Grim's Tiger Revenge Quest.
    * removed the hail questsay from Guard Donlan and Guard McCluskey since it already in the database.
    Misc:
    * Generated new path file for Guktop and Gukbottom so combat pathing should improved greatly.
