2-24-2016
Discussion in 'Changelog' started by robregen, Feb 24, 2016.
    * Fixed SE_CurrentHPOnce not updating the client properly.
    * Fixed the long time spawn_conditions crash.
    * Bind Sight will now be castable on targets in a different region.
    * Players with See Invisible will now properly see other players who are hidden/invisible server side.
    * Added a spot where Voice Graft should be faded when a pet leaves.
    * /who all lfg will now function.
    * /who all will now use a player's base race instead of their illusion race.
    * /who is unaffected by both changes.
    * Some minor logging changes.
    * Updated how character inventory is sent when zoning. This should improve zone times.
    * Added checks for items in no rent bags, so their deletion can be logged better, if the no rent bag expires.
    * Returned position update frequency to original setting.
    * Fixed a legacy netcode issue that makes it look like client is lagging, when they really aren't.
    * Added some checks to improve the reliability of trading and prevent item loss.
    * Clients will no longer get group bugged, when they accept joining a group, but the group is already full.
    * More fixes for groups getting bugged when someone gets disconnected while zoning.
    * Changed some pet checks to be less CPU intensive.
    * The melee mitigation algorithm has been updated for more accuracy. Very low level player and NPC mitigation in particular will be noticably more accurate.
    * The player character damage multiplier function is now more precise.
    * Weapon elemental damage now uses a simple function taken from a decompile instead of using the spell resist function. (decompile credit: Demonstar)
    * Ripostes may now trigger from other ripostes. Client attacks while under a riposte discipline are now unripostable.
    * AC buffs on NPCs fixed to not increase AC more than desired.
    * Avoidance bonus from agility capped at 200 agility.
    * Melee avoidance and mitigation AAs are now implemented and verified to be correct.
    * fixed faction for Bloodgill Goblins in LoIO.
    * fixed the mushroom groundspawns in North Kaladim.
    * Added a missing NPC "Draketamer" to Frontier Mountains.
    * Added some missing static Gnolls in Blackburrow.
    * Fixed the gate in Sol A to open all at once.
    * Added a missing NPC "a soothsayer goblins" in Temple of Droga.
    * Added missing loot "Drogan obsidian dagger" to goblin whipcracker in Temple of Droga.
    * Added missing loot "Write of Di'Zok" to Korucust's Courier in Chardok.
    * The door to Aeris Greymalkyn in Highkeep should now be perma-lock.
    * Added a missing spellset to Froglok Dar Wizard in Sebilis
    * Added a missing faction to "a rotting skeleton" in Nektulos Forest.
    * All giants and cyclops including Hill Giants, Seafuries, and Forest Giants should now be immune to stun and mez (verified on live)
    * Ssolet Dnaas should now be KOS to all except Iksars.
    * Added a kobold missionary to Steamfont as part of a Eruden / the Warren quest.
    * restricted turn in to Surran on the appropiate islands for Plane of Sky.
    * added timer to Bazzt_Zzzt in Plane of Sky to depop within a time limit.
    Harakari
    * Tazgar - Added faction hit on Hail and message triggers
    * Tam Visilin - Added Message Trigger
    * Pungla: Added message triggers and turnin
    * Lokar To`Biath - Fixed Faction Rewards for Red Wine and Scribe of Dal Quest; Added missing text trigger
    * Rysva To`Biath - Fixed Faction Rewards for Scribe of Dal / Book of Turmoil Quest
    * Sister of Erollisi : Added missing text triggers
    * Styria Feamon : Fixed Faction Reward for Pirate Earing and Erollisi Bracer Quest and Fixed Reward Messages
    * Sinnkin Highbrow : Added missing message trigger and Fixed Faction Reward
    * Phloatin HighBrow : Added missing text trigger
    * Fixed Faction Reward for Regurgitonic Quest
    * Frostbite: Add missing message trigger and added faction reward and text for Regurgatonic Quest
    * Te`Anara: Added faction checks for starting Regurgitonic Quest
    * Gregor Nasin: Fixed Faction Reward for turnin related to Barkeep Compendium
    * Clurg: Added Faction checks for message triggers regarding clurgs revenge and the exotic drink quest
    * Clurg: Added real message for starting imposter Quest
    * Clurg: Fixed Faction Reward for turnin of Clurgs Revenge and Exotic Drinks
    * Clurg: Added required faction checks for turnin of Clurgs Revenge and Exotic Drinks
    Misc
    * updated hole pathfile.
    Oiwon and Ransom like this.
    Writ :)
  3. Ransom
    Always impressive. Great work.
