Code: Torven * When NPCs are pushed via melee or spells, they will now update their position twice as frequently. * Summon timer for NPCs under level 66 is now 11 seconds. Solar * adjusted some duration based spell effect value calculations * fix a client/server targeting desync after fear wears off * ranged timer reset tweak * speed up rogue sneak. sneak speed will be same as normal run speed at level 60, and faster than running at 65. * apply Shroud of Stealth sneak/hide when using rogue Escape ability * more reliable unlock client controls after charm/fear wear off Database: Torven * pofire: Phoenix boss charm should now only land on the tank. * pofire: Fixed some loot tables on rare spawns to always drop 1 item. * pofire: Damage removed from Juxtapose of Fire spell. Robregen * Holy Order of Mithaniel: charges should no longer show in the item info window. * Anger of Incapacitation: should now be combinable in Mortar & Pestle container. * Midnight Stones and Sandstones Pearls: should only be crushed in Mortar & Pestle container. * hohonora and potactics: zone should no longer go idled if zone is empty of characters. * hohonora: A Undead Miniature should now be undead. * Hero Sandwich: should now be combinable in oven. * poeartha: a decaying spelunker should now be undead. * Celestial Essence: should now be combinable in any mortar and pestle type container. Quest: Torven * povalor: Larvae will no longer burrow while charmed. * potactics: Failing the RZ script in phase 2 will no longer leave the pit spawns permanently disabled. * hohonora: Added a back-up measure to prevent hero shrine guardians from stacking in case of idle zones or script failure. * vexthal: Fix for some trap mobs not despawning. * pofire: Field 1 mobs now have a chance to be snare immune. Robregen * poknowledge: Aid Grimel should now give 3 piece of fementing dust instead of 3 stacks. * poknowledge: Elemental Somat should no longer give out Firebold of Tallon as one of the possible spell when turning in Ethereal Parchment. * thurgadina: Meg Tucter: add a missing questsay when asked about pure enchanted velium.
