12-9-2015 crash fix and misc
Discussion in 'Changelog' started by robregen, Dec 9, 2015.
    * conning pets crash fix
    * Fixed some rounding issues with clients vs server locs.
    * Client and Server will round their positions the same way now, when converting x and y coordinates from float to int.
    * Changed encoding for ServerZoneEntry_Struct to be direct, so as to not round positions and heading. This helps prevent client loc and heading changing when logging in.
    * Fixed an issue with the z adjustment for clients, using zone geometry when logging in. It was not updating correctly based on the real value for bestz.
    * Changed Datatype to Real for Succor fail chance and set it to 0.5 by default.
  2. Cerebro
    Cerebro Member
    When you log in you will no longer be /role to yourself but will still be to others. Logging in and out does not fix the issue, only does it again.
  3. robregen
    okay I will apply a hotfix in a bit as it affect GM as well.
  4. Cerebro
    Cerebro Member
    There seems to be something very wonky with gate since the patch today. Gates collapse almost endlessly. This isnt fizzling the spell is getting casted but the gate collapses once casted. Could this be due to one of the changes today? 235/235 casting skill, maxxed specialization, level 60, 227 wis if that has anything to do with it.
  5. robregen
    it should be fixed now.
  6. Throy
    Throy Member
    Pretty confident now that this patch also broke feign death clearing faction hits.
  7. Throy
    Throy Member
    Oddly, happened about 5 out of 6 times.
  8. Bum
    Only clears faction if you are this tall.
