Code: Torven * Being drunk will now reduce to-hit and avoidance by the appropriate values. (credit to Demonstar for the client decompiles and pseudocode) * Worn item atk is now factored into offense calculations. * Worn item atk is now capped at 250. * AC from buffs is now calculated correctly. AC buffs will be much more effective now. * Avatar from primal weapons is now hardcoded to add to item atk instead of spell atk as per Demonstar's client decompile, making atk from primal weapons subject to the item atk cap. * Bonus mitigation from agility is now calculated using the eqmac client formula instead of the modern EQ formula. (credit to Secrets for the decompile) * Bonus avoidance from agility is now estimated to approximate the eqmac client formula instead of the modern EQ formula. * Spells with a -hate component will now work correctly. (e.g. jolt) Robregen * Readjust wolf size (thanks to Harakiri suggestion) * change default value in rule tables for succor failed chance to .005 to refect the .5% Database: Torven * hole: Slizik the mighty is not longer flagged immune to magic. Robregen * Added a mixture of NPC in Sol A to be more diversify. * Added a misssing forage "Papaya fruit" to Shadeweaver * Removed Cactus pulp and Ro Date from Oasis's forage list * Forager and Hunter in Trakanon should now drop spectral bow 100% of the time. * Rogue should now be able to sneak and hide in Sebilis except for the crypt area. * a alchemist's acolyte in Chardok should now always drop an item. * Dread Widow should now show the correct model in Dreadland.
oh forgot about that one. yes He should. I'll make a note of it. I didn't touch the wizened mob yet. need to research it still.
