12-14-2016
Discussion in 'Changelog' started by robregen, Dec 14, 2016.
    * Harm Touch and Lay on Hands will now sync better between server and client.
    * More player timers are now cleared on death.
    * Implemented Spell Casting Reinforcement and Mastery AAs.
    * The server and client should now remain in sync when Mend is used and the player zones.
    * Changed the timer ability error to be a log, instead of a player message.
    * Suspended Minion will now restore suspended pets properly.
    * UCS fixes to use a consistent method of stream interface deletions.
    * Netcode fixes - Changed how resend are flagged for packets.
    * Changed forced disconnect for desynced clients.
    * Fixed an issue with going LD, bugging groups in raids.
    Spell Partial Determination Logic Change
    * IsPartialCapableSpell() has been changed to return true if the spell's first effect is effect id 0 or 79 (damage), else it will return false. It will no longer return false if the spell has a duration. Dispel effects are no longer ignored. Dragon AoEs will still partial as their first effect is damage.
    * The result of this change is that certain raid boss spells will now use the 600 resist scale instead of the 200 scale, and will partial hit even if the spells have effects like stuns or AC debuffs. This fixes it to function as Sony's spells do.
    * Some player spells will now also hit better. Enchanter DDs will now partial hit. Druid magic DoTs and necro fire DoTs will now hit much better.
    * Chuckles the Great in plane of mischief should now corpse camp.
    * non humanoid illusion should now be KOS to the denizen of mischief and not be kos to KOS mischief NPC.
    * fixed the phantom weapon on siren seductress in Cobalt Scar.
    * fixed the trivial on Silver Jasper Ring combine.
    * fix MQ Dire Wolf Fur to not disappear if try to get a 2nd.
    * Guards in PoM should now drop crowns.
    * Crystal Scimitar, Crystal Hammer, and Great Sword of Bristlebane added and replace in various PoM recipe.
