Code: (Cavedude) Added the two boat PP fields to character_data. (SQL 2014_11_13_boats.sql is REQUIRED.) Conversion from the old BLOB format now handles these added columns automagically. Properly implemented the mac client version system without touching the DB. Added new Unused client to clientversions and eq_dictionary. My next longterm project is to add basic Trilogy support, at least for reference. Changed the #cvs command to report our clients instead of EQEmu's Used new MacIntel bit to exclude other clients from being affected by the Intel client's crude duplicate packet workaround. Removed some versioning code which was preventing LogServer from being sent to clients properly. Some code cleanup and removal. NPC walkspeed is now pulled from the DB instead of being derived from runspeed. I changed boats walkspeed in the DB so they are not broken again for now. Cient walk and runspeed should now be correct. Character:BaseRunSpeed rule should be 0.7, and Character:BaseWalkSpeed rule should be 0.46. Database: (Robregen) Adjusted coins drops for Sand Giants equilivient to Hill Giants. Blazing Elementals in Solusek Eye are now KoS and their DS should work now. Kindle no longer shares a static spawns and now share a roamer spawn. Scripts: (Robregen) fixed the Scripts for Genni when turning in for Galvanized Platinum Bar.
