Code: (Cavedude) * LD characters are no longer counted towards the total character count when checking the session limit. This should allow players to get back on right away in most cases after going LD in-game. * Fixed eq.attack, eq.attack_npc, eq.attack_npc_type * NPCs that are engaged with PROX_AGGRO set will now only add clients that are within combat range to their hate list. * Fixed the crash when /guildremove is used and the player is not online or in the same zone. * Increased column sizes of commands_log when it is first created. * LD will no longer break FD. * Fixed triple linked doors not opening for NPCs. Added an exception for doorid 2 in neriakb as it seems to have range issues. * Changed 0 to false in ResistSpell call, since it's a bool. * Implemented mob equipment light sources (credit to Uleat from eqemu) Torven * charm ticks, root ticks, and pac crit resist fixes Robregen * merge eqemu"s KLS updated version of glm replacing the prevoius position update. (credit to KLS) * Use lambdas in sort functions (for zone at least) (credit to Demonstar) * Rewrite StringFormat to take advantage of RVO (credit to Demonstar) Speedz * Additions to #testcopy Database: Robregen * fixed the Recipe for small piece of ore from a tarnished weapon. * fixed the loot table for Glacier Bear in Everfrost. * Set the respawntimer to 8 hours for Glacier / PH in cave. * Removed Lich_of_Miragul from Glacier Bear spawngroup. * Xicotl should now drop the Glowing Sword Hilt every time. Torven * mistmoore: Raised the aggro radius for some dark elf NPCs up to 60. (apparently I missed them the first time) * kedge: ferocious hammerhead moved to his proper spawn location. * oot: created a Allizewsaur loot table, replacing the sparse magelo one
