1-25-2016
Discussion in 'Changelog' started by robregen, Jan 25, 2017.
    * Discipline timers will no longer be cleared on death.
    * LFG will now be cleared when a player accepts a raid invite, or for both players when a raid is created.
    * Corrected an issue where a group leader could not use group chat until they zone.
    * Players in a group will now receive a message when another player attempts to invite them to another group.
    * Players with 201 skill or higher in Bind Wound can now heal up to 70%.
    * TGB will no longer work on items with group spell click effects.
    * NPCs will now assist if the attacker is a red con in NPC vs NPC combat. Players and player pets are not affected by this change.
    * Corrected an error in some pet names causing spaces to be removed when damage is reported.
    * Rogue poisons that are applied to piercing weapons will now only proc once on the first successful normal attack and then will fade.
    * Ranger archery bonus will now be applied to permarooted NPCs.
    * QuestReward() will no longer give faction hits if the NPC is charmed.
    * Corrected an issue causing pet health to exceed 100%.
    * Corrected spell stacking rules for resurrection effects and for beneficial vs detrimental spells with an AC effect in slot 4.
    * Optimized /consent a bit to hopefully prevent an issue causing consent to be denied when it shouldn't be.
    * Ignore distance now has a timer that starts when the entity has outdistanced the NPC. When the timer expires, the entity is removed from the hate list. This time is currently set to 180 seconds, but what it was on AK was unknown. Debate welcome.
    * NPCs will now not ignore mobs that outdistance them AND have damaged them until 24 seconds have passed. Entities that have done no damage will be ignored immediately after exceeding ignore distance.
    * NPCs that have nobody in range to chase will now loiter (if they are loitering NPCs) before returning home. When they return home, they will remain at run speed so long as they hate somebody.
    * NPCs will no longer forget non-feigned players once they reach their home points.
    * Added an exception for increase client combat range for velious dragon race type in Temple of Veeshan.
    * memleak fix for world container object (credit to deomonstar from EQEmu)
    * Correct the spellset for a lava dancer in ToV.
    * Highpass Gnolls should now loop around toward Highkeep instead of toward Kithicor.
    * correct the faction for Lobal Postugger in Ak'Anon.
    * correct the faction for Kszan Punox in Neriak Third Gate.
    * Blazing Elementals should no longer attack the Goblins in SolA
    * slightly increase the drop rate for Shadowed Books and Shadowed Balls from Shadowed men.
    * Added missing NPC "an exiled legionnaire" in Cauldron.
    * Added missing NPC "Marlin Shirtov" in Highpass.
    * Fixed the Dismal Priest Breastplate Recipe.
    * Fippy Darkpaw should now spawn at various location before he makes his way toward the Qeynos Castle.
    * Squire Wimbley should now be at the correct location in East Karana.
    * Added a missing "a putrid skeleton" and his placeholder "a dwarf skeleton" in South Karana for the quest "Cromil's Remains".
    * the item "Dwarf Bones" should now drop from the right putrid skeleton in South Karana.
    * Added a missing NPC "Oculys Ogrefiend" in Rathe Mountain
    * sleeper: Ventani MR increased.
    * Charmed NPCs will no longer give faction hits in quests.
    * moved faction check for Caradon in The Hole.
    * fixed a variable in relating to Velious Kael bracer armor quest.
    * add a depop with timer for Lord Elgnub and PH to emulate live like in Blackburrow
    * Update orc runner scripts for kelethin.
    * Readjust faction required and faction reward for Bumle Reminjar in Kaladim.
    * Added missing texts for Bumle Reminjar in Kaladim.
    * Readjust faction reward for Gunlok Jure "Cromil's Remain" verified from Live in Kaladim
    * readjust faction and xp % verified from live for blackbox quests in Ak'Anon.
    * readjust faction reward for Dature Nightseer in Kaladim.
    * readjust faction reward for Dru Razbind in butcherblock.
    Harakiri
    * Aenia Ghenson: Now uses the current Players Name when talking not a hardcoded one
    * Behroe Dlexon: Now Rewards the Shawl of the Wind Spirit
    * Vynon Estaliun: Added Faction Check and Fixed Faction Reward for Catfish Tail Quest
    * Laoni Reista: Added Faction Check and Fixed Faction Reward for Cleanse the Ocean Quest
    * Rodgar the Tall: Fixed Faction Reward for Peacekeeper Staff Quest
    * Emil Parsini: Fixed Faction Reward for Peacekeeper Staff Quest
    * Lumi Stergnon: Add Faction Checks for all Quests, Add Missing Dialog regarding High Guard Staff, Fixed Faction Reward for Skeleton Killing Quest, Fixed Faction Reward for Peacekeeper Staff Quest
    * Weligon Steelherder: Added Faction Check for all Quests, Fixed Faction Reward for Deep Six Cutlass Quest, Fixed Faction Reward for Barnacle Breastplate Quest, and Fixed Faction Reward for Odus Pearls Quest
    * Breya Nostulia: Added Faction Check for Midnight Sea Mail Leggings Quest
    * Gans Paust: Added Faction Check for Midnight Sea Mail Sleeves Quest
    * Dleria Mausrel: Added Faction Check for Fisherman and Zombie Flesh Quest and Fixed Faction Reward for Fisherman and Zombie Flesh Quest
    * Bait Masterson: Fixed Faction Reward for Guild Tunic
    * Agryn Moonfield: Added Dialog about guild coin
    * Leraena Shelyrak: Added Faction Check for Guild Coin/Kobold Quests
    * Jras Solsier: Added Faction Checks for Poacher Quests and Fixed Faction Reward for Poacher Head and Barbarian Head Quest
    * Tralyn Marsinger: Fixed Faction Reward for Bard Mail Quest and Fixed Faction Reward for Mail Delivery
    * Shondo Billin: Fix Faction Reward for Vasty Deep Ale Quest
    * Josper Kenshed: Added Faction Requirement for Ice Goblin Beads and Ilanic's Scroll and Fixed Faction Reward for Ilanic's Scroll
    * Markus Jaevins: Added Quest for Magicians Bones and Fixed Faction Reward for both Bones Quest
    * Shintar Vinlail: Added missing dialog
    * Toresian Fhabel: Added Faction Requirements for Inert Potion
    * Slansin: Fixed Faction Reward for Inert Potion Quest
    * Vasile Jahnir: Added Faction Requirement for Gloves of Gatecallers and Rungupp Quest and Fixed Faction Reward for both quests too
    * Dok: Fixed Faction Reward for Everburn Candle
    * Margyn McCann: Added missing text Trigger and Fixed Faction Requirement for Head of Granin O'Gill Quest
    * Waltor Felligan: Added correct Faction checks for Fungus Quest
    * Cappi McTarnigal: Fixed Faction Reward for Mammoth Claf Quest
    * Ysanna MacGibbon: Fixed Faction Reward for Gnoll Fur Quest
    * Cindl: Fixed Reward Text
    * Shamus Felligan: Fixed Faction Requirement/Faction Reward/Text for Shattered Caster Beads and Fixed Faction Requirement/Faction Reward/Text for Caster Beads
    * Lysbith McNaff: Added Faction Checks for orc wristband and goblin necklace quests and Added missing keyword trigger
    * Carver Cagrek: Added Faction Reward for Grobb Cleaver Quest
    * Nerbilik: Fixed Faction Reward for Grub Locker Quest
    * The Gobbler: Added Faction Reward for Preserved Leg Quest
    * Chef Dooga: Fixed Faction Rewards for Butcher Appron, High Elf and Human Flesh Quests
    * Guard Shilster: Fixed Faction Reward for Black Burrow Stout
    * Holana Oleary: Added Faction checks for Karana Clovers Quest
    * Cindle: Fixed Faction Reward for Polar Bear and Wristband Collection
    * Jinkus Fellingan: Fixed Reward Message
    * Iceberg: Added Hail Trigger and Adjusted Faction Reward for Lions Delight
    * Teria O Danos: Fixed Faction Reward for Lion Meat Shipment and Fixed Text Trigger for lion delight
    * Junth McMannus: Added Hail Trigger
    * Brenzl McMannus: Added Hail Trigger
    * Ulrich McMannus : Added Missing Text Triggers
    * Lars McMannus: Added missing Hail trigger
    * Sera McMannus: Added Missing Hail Trigger
    * Einhorst McMannus: Added missing trigger phrases for halas and home and Added triggers for Misla
    * Misla McMannus: Added Missing Hail Trigger and Fixed that you now get Lion Meat Shipment from her too
    * Renth McLanis: Fixed Faction Reward for Ivan McMannus Remains Quest, Adjusted Faction Requirement for trigger phrases, and Fixed Faction Reward for Langseax Quest
    * Dargon McPherson: Fixed Faction Reward for Elixir Quest
    * Megan OReilly: Fixed Faction Reward for Elixir Quest and Added Faction Check for Ivan's remains Quest
    * Arnis McLish: Fixed Faction Reward for Elixir Quest
    * Bryndin McMill: Fixed Faction Reward for Elixir Quest
    * Talin ODonald: Fixed Faction Reward for Elixir Quest
    Mokli, showstring, Ransom and 2 others like this.
  2. robregen
    patch note updated.
  3. Senani
    Senani New Member
    Thanks for all the work you guys do.
  4. showstring
    amazing work once again, thank you
  5. Dimitri Ex'Zemos
    Dimitri Ex'Zemos Active Member
    Hooray! No more Incap overwriting Aego!!
