1-17-2015
Discussion in 'Changelog' started by robregen, Jan 17, 2015.
    (Cavedude)
    * Added two new columns to npc_types, combat_hp_regen and combat_mana_regen. These determine the regen for NPCs while in combat. The existing columns hp_regen and mana_regen should be used while out of combat.
    * NPCs will now use spell/item regen bonuses at all times.
    * I left CalcNPCRegen() intact until the DB is sorted, at which point I will remove it. The new columns default to 1.
    * Robregen identified string type 4, and I replaced all instances of it with a name.
    (Robregen)
    * rearrange the tradeskill trivial message. It should now display properly.
    (Robregen)
    * fixed the position for Innkeep Lynnie in Kithicor
    * fixed the forge in West Freeport
    * Added Thunderhoof Mushroom to forage list in South Karana
    * fixed small lantern and torches to not acts like stackable items.
    * Rearranged Cats loottables so one pelt would drop at a time.
    * Generated new loottable for Sir Lucan in Freeport.
    * Generated new loottable for King_Kazon_Stormhammer
    (Torven)
    * Removed Patriach in Kedge from swirlspine spawngroup
    (Robregen)
    * Change the location for Swirlspine Guardian in Kedge Keep
