1-14-2014
Discussion in 'Changelog' started by robregen, Jan 14, 2015.
    (Robregen)
    split up spawngroups in Field of Bone pit so lower part of pit has more low levels.
    shrink down the roambox in Field of Bone Pit to fix bouncing NPC.
    Change the faction to a scaled wolf pup in FoB to be threateningly.
    Change the faction to a scorpion in FoB to be dubious.
    Added loots to High Keep Guards so they should now drop fine steel short sword.
    Changed the respawn timer to all High keep Guards to 18 minutes.
    Changed faction to neutral beta to Tarn Visilin in High Keep
    Changed faction to Merchants of Highpass / Carson McCabe/ Highpass Guards to Bank Clerk Jaylin
    Fixed Warlord Skarlon itemization so it'll drop main loot instead of throwing boulders.
    Removed negative Karana faction from Keepers of the Arts so Karana Deity should no longer be KoS.
    Removed faction hits for Inhabitants of Unrest.
    Changed faction to Beggar Wyllin to be KoS.
    moved pathing for Yendar Starpyle in Steamfonts.
    Added missing loottable for minotaurs in Steamfonts.
    increased the spawn chance for Deathfist Scout in Nektulos.
    fixed spawn condition for Tani N'Mar in Neriak 3rd Gate.
    Added and adjust faction hits for Tani N'Mar in Neriak 3rd Gate.
    (Torvan)
    soldungb: kobold advisor damage set to precise values, attack delay reduced, MR and FR increased, flagged immune to non-magic melee.
    soldungb: kobold guardian damage set to precise values, attack delay reduced, FR increased.
    soldungb: fire giant wizard mana regen increased.
    soldungb: Magus Rokyl's damage reduced (values an estimate), and mana regen increased.
    kithicor: Brigadier G`tav set to drop two Indigo Sabres.
    kithicor: The cabin DEs had their attack delays reduced, spell sets applied, aggro radii increased, resist values raised, hitpoints increased, summoning flags set, emotes set, and respawn timers significantly lengthened.
    rathemtns: Hasten spawnpoint respawn increased to 10 minutes.
    Default enchanter spell set priorities adjusted; hopefully they'll be less dumb now.
    oot: Sister Isle NPC aggro radius reduced to 30 from 70.
    oot: Gargoyle aggro radius reduced to 35 from 70.
    oot: Goblin aggro radius reduced to 30 from 70.
    oot: Siren aggro radius reduced to 35 from 70. (estimate)
    kithicor: Cabin DEs' resists and attack delays set to parsed values.
    (Robregen)
    adjust faction reward value to Beno_Targnarle in Kaladim.
    adjust faction reward value and removed wrong item from Doran_Vargnus in OoT.
    increased experience reward for Priestess_Caulria in Qeynos.
    added missing missing Reward to Verona_Rankin of East Freeport
    correct the item reward to Tabure_Ahendle
    Quest:
    (Speedz)
    Fixed quest reward for Library Book in Eurdin
