Where's good for AE PL after Kurns?
Discussion in 'General Discussion' started by Lusiphur, Dec 8, 2019.
  1. Lusiphur
    Lusiphur Member
    Kurns dries up by 20 and I need to get a Cleric to 29. All suugestions gratefully received. I have an ENC and DRU available.
  2. gardnerjens
    Sol A is pretty good
    Ripwind likes this.
  3. Yarnee
    what i usually do is pull highkeep basement with dru, chloroblast self and cast ds tag with lowbie
  4. Animalevic
    Animalevic New Member
    Second on solA.
  5. Mechaike
    Mechaike Well-Known Member
    Unrest, Sol A. If 29 is the goal, unrest may dry up sooner than Sol A.
  6. Sketchy
    Unrest is awesome. I have done low 30's in the basement there.
  7. Darchon
    I do 1-10ish in Kurns
    10ish-35ish in Unrest
    35ish-46 in Lower Guk
    I prefer undead mobs since they don’t flee but even in Guk they will flee.
    Doing 35-45 may be faster in HHK due to the high ZEM but I’ve never been a fan of trashing factions generally. Plus HHK was the go to grouping spot for new players in the level range on AK and it was considered disrespectful to PL here when players were trying to level their first characters. But there was normally plenty of opportunities to PL there when it was empty regardless.
  8. Mokli
    This is precisely what I usually do. LGuk is slower than other zones I'm sure, but it also is beneficial if you are ever going to do the crown of deceit quest on that toon anyway. Everyone needs the faction to do it.
  9. Faults
    I do 1-16 in kurns, 16-34 in hhk 34-40 droga - 40-54 grimling infinity spawn was the best path ive had so far.
    Slayzz, Mokli and showstring like this.
  10. Walex
    I like to do Kaesora after Kurns. It can take you all the way to 40 but usually slows down in the mid 30's. Break the zone into three pieces (library, spiders, church) and pull them to the zone in. Once you get good at it you can kill everything in the zone with a minute or two of downtime. As a bonus, you get your xalgoz fang for HS.
  11. Haynar
    I like Kurns til 15-20ish. Then to keep it simple, Mistmoore to 40.
    Mechaike likes this.
  12. Devour_Souls
    Off topic a bit, but I would recommend going to 30 for specialization. I did this a while back and it took about 1 day. I went Blackburrow to 8 and then turned in gnoll fangs to ding 10 or eleven, Kurns to 16, PC to 24, Highkeep to 30.
  13. Darchon
    This thread compelled me to powerlevel an alt Id been slowly dropping gear on in PoK that was still level 1. Including about 30 PBAE Holgresh Wands
    Went to Kurns, pulled all of first floor skeletons, used 2-3 clicks of a wand and that train got me to level 4.5
    Pulled all the upstairs skeletons and got to level 10. So if your toon has some holgresh AE wands or has AE spells you can get 1-10 in just 1 clearing of the main and top floor of kurns.
    Went to Unrest and got to level 20 after 2 pulls of yard and first floor and 1 pull of the top floor.
    Then inbetween many AFKs I grouped my 20 beastlord with a 19 wizard and managed to get around 1 level per pull of either the basement or the top floor for both characters up until level 30. Ended up spending rest of the night skilling up melee skills and casting skill.
    If you’re PLing a single character though I think Kurns->Unrest can get you 1-40 in a day given you have a decent druid or healer + tank with non-Damage primary and some form of DS.
  14. Thunderace
    Thunderace People Like Me
    Unrest is bad, lots of scary mobs there! stay away!
  15. Mechaike
    Mistmoore is also amazing for AEPL, did this a bunch on AK.
  16. Ripwind
    Ripwind People Like Me
    Funny, I was just PLing a wizard over the weekend. Here's the path I took.
    DS PL in The Warrens (Dru)
    Fri Dec 06 20:29:41 2019 2
    Fri Dec 06 20:31:10 2019 3
    Fri Dec 06 20:32:25 2019 4
    Fri Dec 06 20:34:51 2019 5
    Fri Dec 06 20:37:58 2019 6
    Fri Dec 06 20:41:47 2019 7
    Fri Dec 06 20:44:50 2019 8
    Fri Dec 06 20:49:53 2019 9
    Fri Dec 06 20:56:34 2019 10
    Fri Dec 06 21:00:23 2019 11
    Fri Dec 06 21:04:51 2019 12
    Fri Dec 06 21:07:42 2019 13
    Fri Dec 06 21:13:38 2019 14
    Fri Dec 06 21:19:53 2019 15
    Fri Dec 06 21:27:41 2019 16
    AE PL in SolA (Bard DS tank)
    Fri Dec 06 21:41:25 2019 17
    Fri Dec 06 21:45:01 2019 18
    Fri Dec 06 21:49:10 2019 19
    Fri Dec 06 21:51:47 2019 20
    Fri Dec 06 21:56:07 2019 21
    Fri Dec 06 22:01:13 2019 22
    Sat Dec 07 07:11:53 2019 23
    Sat Dec 07 07:16:09 2019 24
    Sat Dec 07 07:32:59 2019 25
    Sat Dec 07 07:33:55 2019 26
    Sat Dec 07 07:37:40 2019 27
    Sat Dec 07 08:30:13 2019 28
    Sat Dec 07 08:34:43 2019 29
    Sat Dec 07 08:53:58 2019 30
    Sat Dec 07 09:06:16 2019 31
    Sat Dec 07 09:21:51 2019 32
    Sat Dec 07 09:28:05 2019 33
    FD PL in Kaesora (Necro)
    Sat Dec 07 09:50:43 2019 34
    Sat Dec 07 10:00:41 2019 35
    Sat Dec 07 10:54:25 2019 36
    Sat Dec 07 11:26:15 2019 37
    Sat Dec 07 11:47:17 2019 38
    Sat Dec 07 12:08:18 2019 39
    Sat Dec 07 12:39:41 2019 40
    Grimling AE (Wiz/Wiz/Enc) - Had some company as well at points.
    Sat Dec 07 14:01:45 2019 41
    Sat Dec 07 14:15:27 2019 42
    Sat Dec 07 14:25:53 2019 43
    Sat Dec 07 14:39:34 2019 44
    Sat Dec 07 14:58:25 2019 45
    Sat Dec 07 15:25:13 2019 46
    Sat Dec 07 15:41:33 2019 47
    Sat Dec 07 15:56:52 2019 48
    Sat Dec 07 16:14:03 2019 49
    Sat Dec 07 22:48:29 2019 50
    Sat Dec 07 23:06:25 2019 51
    Sun Dec 08 07:45:25 2019 52
    Sun Dec 08 08:47:12 2019 53
    Sun Dec 08 10:11:46 2019 54
  17. Ravenwing
    That's a neat trick with the holgresh wands, Darchon. They work from inventory for any class?
    I've always started in Kurns -> Sol A (though I hear Unrest is just as good), and I suspect that the infinite Grimling pile is best from there. On Al'Kabor (where it may have contained more mobs) it certainly was, and I kept a level 56 wizard just for the purpose of PLing from 37-51 or so there.
    BRD/DRU is probably the best class combo for DS PLing.
  18. Ripwind
    They do work from inventory for any class. Best way to do an AE/DS PL for a melee class for those early levels. And the recharge cost is suuuuper low, like 5 plat per wand.
  19. Faults
    Its part of why I like HHK so much - vendors right in zone.
  20. Darchon
    They do indeed work from inventory by any class. The Holgresh in Wakening Lands can drop 1 of 4 wands. Two are PBAE and two are single target. The PBAE wands use Cast Force and Flame Flux and are clickable at level 1. They’re actually quite respectable damage until level 20 or so. About 80-100 per target per click.
    In the process of farming about 300~ furs and wings for tinkering, which somehow netted me only 2 skillups (still raging over this), I was able to pick up about 40 of the PBAE wands. Which I stored up just to PL this beastlord. Then I decided I was lazy and would just group the beastlord with a wizard and not use any charges after going through only 2 wands to get to level 20.
    Sol A is also great but I find people tend to favor slaying gnomes which I can generally get behind but I like to avoid faction hits, and I think Unrest can carry you higher than the Sol A goblins can alone. But in the high teens to mid thirties I believe both of these are good camps for PLing.
    I’ve also found that in LGuk due to the interrupt code we have, it’s far more efficient to CH my Paladin and accept the 10 lower DS than try to tank on my druid. It’s mind boggling how easily normal melee hits interrupt from green cons. I’ll go from 100-dead and see probably 20 heal interrupts while corner tanking a train of frogs.
  21. Lusiphur
    Lusiphur Member
    This. I have been using a 50 druid (because it is all I have) and any more than 3 or 4 mobs from Unrest basement is asking to die. That would be different at 60 ofc but still I would think Unrest is the cut off for any kind of Druid DS tanking unless you have insane gear.
    I was just about to ask how you would do classes with no AE, apart from making a throwaway BRD to group with them. Nice tip there.
  22. Nakunaru
    Nakunaru People Like Me
    I would say just make a level 1 wizard along with whatever class you'll be plvling to bring along, then just drop the wizard around level 40.
    Ripwind likes this.
  23. nworbetan
    nworbetan Member
    I haven't done very much power leveling in EQ, but I'm pretty sure I'm learning some good info here. Thanks for all the tips so far.
    I think I understand the gist of using FD to PL, but there's a couple of the details I'm kinda hazy on still if anyone can clear those up. Are there any issues with the necro doing too much damage, or continuing to do damage after FD, say with a DoT maybe? Also, what are the conditions that remove the FD char from the exp list, does every successful FD do that?
  24. Cadsuane
    You're slightly missing it -- you stay FD, and pet does it all. Then no damage at all is attributed to the necro.
    DoTs definitely re-agro after a successful FD, though I'm not sure of the damage assignment mechanics.
    If someone has done a highly-in-depth analysis of damage assignment in relation to FD, I'd be interested to read that also though. There were some bugs in the past with still taking raid faction hits even when FDed, and I never got around to investigating in depth.
