Tinkering and gnome cultural question here...
Discussion in 'General Discussion' started by NarcolepticLTD, May 31, 2016.
  1. NarcolepticLTD
    NarcolepticLTD Member
  2. robregen
    by looking at the EQ item id. I doesn't look like it was on AK.
  3. NarcolepticLTD
    dang... was hoping with the celestial tempers it would have been added prior to pop - and therefore been part of the DB on AK. No clockwork rogue armors for my gnomesies :/
  4. NarcolepticLTD
    Robregen has earned a new title! Robregen the Dream Crusher.
    Ransom, Neealana, Bum and 1 other person like this.
  5. thucydides
    They werent on AK, the blue diamond combine didnt work, i tried.
  6. NarcolepticLTD
    Are you referring to Celestial Tempers? I believe those are turned off in the code right now to keep people from making some of this stuff before velious/luclin happens.
  7. Lenas
    Celestial essence is disabled, not tempers. Thucy is saying the temper combine did not work on AK.
  8. robregen
  9. Lenas
    Man my memory isn't what it used to be. Is thucy wrong about the blue diamond combine not working on AK then? Thats the only thing I can see in the clockwork recipes that uses a BD.
  10. Ravenwing
    The celestial temper certainly worked on AK - it's used in all BD cultural armor. Perhaps Thucy means that clockwork watchmen's armor (the basic cultural set, which is largely useless) worked, but not the blue diamond upgrades (clockwork observer's, etc.).
  11. NarcolepticLTD
    Right on, just wanted to make sure I was on the same page... this is in-line with the Dream Crusher so all is well.
  12. Bum
    useless items
    nomes are better used for footballs
  13. MikayahEQ
    MikayahEQ Well-Known Member
    If you weren't so tall I'd kick you in the kneecaps for that comment!
  14. NarcolepticLTD
    I have a shiv you can borrow, just stick it between his toenails.
  15. MikayahEQ
    Dang, that escalated quickly. Big difference between a kick to the kneecap and shiving a toenail.
    Besides have you seen the size of his stompers.../shudder
  16. NarcolepticLTD
    I actually saw some halfling parts wedged in there...
  17. thucydides
    Infused gears is the combine thst didnt work, sorry. The step where you bring the blue diamond business into tinkerland.
