Iceflame of E'ci
Discussion in 'General Discussion' started by Malcyte, Aug 18, 2023.
  1. Malcyte
    Malcyte New Member
    As far as I can tell, this does not apply to Lure of Ice. As I do not have ancient destruction or gelid, I cannot test. According to the spell information, it should apply to all of these. Can we get an explanation of why this is or can it be looked at if this is not known? Spell Details Below:
    • Increase Spell Damage by 30%
    • Limit: Instant spells only
    • Limit: Resist(Magic allowed)
    • LimitMinLevel by 60
    • Limit: Max Level (60)
  2. solar
    Why do you think it doesn't apply?
  3. Mokli
    Seems to work for me. After removing all of my +damage focii:
    [Fri Aug 18 11:07:17 2023] Your Shade Stone Amulet shimmers briefly.
    [Fri Aug 18 11:07:17 2023] You begin casting Lure of Ice.
    [Fri Aug 18 11:07:20 2023] a widow hatchling was hit by non-melee for 973 points of damage.
    [Fri Aug 18 11:07:20 2023] A widow hatchling succumbs to the lure of ice.
    [Fri Aug 18 11:07:20 2023] You have slain a widow hatchling!
    [Fri Aug 18 11:07:20 2023] Your Boots of the Wind flickers with a pale light.
    Testing with damage focii on is tougher though since there is no emote or anything when it fires. And the Eci's spell acts like a focus, its random up to 30%.
  4. Malcyte
    Malcyte New Member
    I didn’t think about the damage focii, I assumed it would stack but those numbers are in line with what I was getting.
  5. Mokli
    Maybe Solar can confirm it is supposed to stack and currently does. I assume it should. The other question would be if it stacks currently with Rizlona's.
  6. showstring
    It's the same as Rizlona so it doesn't stack.
    But worn focus + iceflame should stack yes, that's the point. Worn + spell focus = stacky
  7. Darchon
    It even works of Wind of Gelid, one of the only damage focuses to work on an AE.
    Mokli and showstring like this.
  8. Mokli
    So no point in Wizards being in Rizlona's groups then as long as they keep that spell up. Melee dps unite.
  9. solar
    They like to use the fire nuke though.
  10. Mokli
    Ah yes, good point.
    In zones like PoFire and Sol Ro's Tower though, it would apply. Just interesting. I suppose they could always cast magic nukes too.
  11. Malcyte
    Malcyte New Member
    Only thing to make me want to use ice would be ancient/gelid
  12. actualspaide
    Even in fire and stuff you can often use magic nuke.
  13. solar
    Iceflame only works on ice resist spells, the information pasted at the beginning of this thread shows magic but that's incorrect. I think you guys know this but just wanted to make it clear for anyone who's reading this and isn't aware - the resist thing for focus spells is not showing the right values on allaclone, but lucy.alkabor.com shows it right https://lucy.alkabor.com/spell_3337.html
    So for the level 60 ice spells you can nuke efficiently without bard song, but for magic and fire the bard song helps. Your best item focus stacks as was already mentioned.
    Hoodlum likes this.
  14. kai4785
  15. solar
    Has to be level 60 spell
  16. actualspaide
    Winds of gellid is a lvl 60 spell. Does it just exclude pbae?
  17. Mokli
    nope
    2 Limit: Instant spells only
    3 Limit: Resist(Cold allowed)
    4 Limit: Min Level(60)
    5 Limit: Max Level(60)
  18. kai4785
    lol, I missed the "min level" bit. What a niche spell.
  19. Darchon
    Well there are 4 level 60 ice spells!
  20. Tryfan
    Zero new pillar spells in pop.
    Zero new pbae spells in pop.
    No upgrade to wizard snare.
    Top level magic nuke is a 0% math fail.
    All evidence suggests the concept of ice nukes for wizard was completely forgotten about and this buff was thrown in at last second to make up for it.
    Greater decession is a grw turn in reward.
    As far as I can tell the dev responsible for wizard in original PoP development never played one above L30. Did they get no feedback during beta ta all?
    When you see garbage development like that at the forefront its a reminder of why WoW so thoroughly kicked EQ's ass soon after.
    Malcyte, Indi and lurari like this.
  21. Devour_Souls
    I don't think you are properly appreciating how much harder Greater Decession decesses than regular Decession. I would think that with good focus, wizard DPS(Decessions per second) would be the best in the game.
    Polly, Ripwind, Kithani and 7 others like this.
