Food and Drink
Discussion in 'General Discussion' started by sourdiesel, Jan 13, 2015.
  1. sourdiesel
    sourdiesel Active Member
    From what I remember food affected hit point regeneration and drink affected mana regeneration (not sure which one was stamina).
    I have noticed on here that food is affecting mana regeneration, is this correct?
  2. Neopolitan
    Neopolitan Member
    I could have swore I was out of food and drink and I was still regening mana and hp...which isn't correct.
  3. Mipa
    Mipa New Member
    only thing I have noticed about food a drink is druids seem to go through a lot more compared to other classes.
  4. Mokli
    The purpose of non-stat food was just to allow you to regain mana normally. If you are out, then regen is like non-existent. If you are still regenning, then that's a bug.
  5. Darchon
    Drink was mana
    Food was HP
    You only stopped regening it when you get the "you are hungry" or "you are thirsty" messages. The out of food/drink messages simply alert you to let you know soon you will stop natural regen if you don't find more.
  6. krenar
    krenar New Member
    food and drink seems to go down faster then normal to me. seems if i leave pok for an hour or 2 i go through 1-2 stacks of each!
  7. iance
    iance New Member
    its bugged. First off, missing either of the 2 blocks both mana regen and stamina regen, when it should just be Mana for Drink and Stamina for Food, and for some reason Bard Heal song doesn't heal me anymore when I'm hungry or thirsty, which is also a bug.
  8. Dragonslayer
    Dragonslayer New Member
    The food and drink on here has been used up faster than any server ive ever played on period. I dunno what it is but seems to be used at a high rate and my char was level 3 and about all of it gone.
  9. Speedz
    Yes you are all correct, it is bugged.
    RossGuy likes this.
  10. sourdiesel
    Wasn't sure if it was bugged or not or I would have put it in the bug section, was just getting community feedback to verify my experience.
    Might be better off moved to the bug section.
  11. Trosh
    Trosh New Member
    I seem to remember that if you had clarity etc. or meditate and you were sitting you would regenerate mana veeeery slowly, and all that being out of drink did was make it so your natural regeneration wouldn't work, which means you need to med like 10x longer because you only have a regen rate of like 3..
  12. Neopolitan
    Neopolitan Member
    Correct.
  13. Darchon
    The sentiment is correct the numbers are not.
    Effects with mana regen (clarity, druid skin, bard songs, etc.) and Flowing Thought, will give you mana every tick regardless of your drink status.
    The only thing drink affected was your meditate mana regen (or the 1 per tick you got while standing).
    Sitting with KEI (14 from KEI) and drink (20 from meditate) gets you 34 mana regen
    Sitting with KEI and thirsty gets you just the 14 mana regen.
  14. Orruar
    Orruar New Member
    I couldn't find a bug for this, so I'll add my observation.
    When I ran out of food/drink and was hungry/thirsty, I continued to regen mana for a couple hours of actual time. Then the mana regen stopped. And as has already been mentioned, mana regen effects (FT, clarity, etc.) should continue to work. Drink (food shouldn't matter for mana) should only affect natural + meditate mana regen.
  15. solar
    You need both food and water to be able to get the standing=1/sitting=2 passive regen and meditate, that's something that is part of the client so I feel confident about that part, but I know our starvation stuff isn't quite right.
    Kithani likes this.
