Couple of mechanics questions re: resists
Discussion in 'General Discussion' started by Ravenwing, Nov 29, 2015.
  1. Ravenwing
    I have been wondering about a couple of things for a while now, and thought I'd ask here on the forums.
    1. Are summoned pets using their masters' resistances in place of their own ("special" pet resists, like fire pet fire immunity, aside)? That is to say, if I want my pet to resist root, should I cast the MR buff on the pet or on myself?
    2. Does root's per-tick chance to break incorporate magic resistance and level differences? Are we currently using whatever default formula for this came from EQEmu?
  2. Tollen
    Tollen Member
    1. cast resists on pet.
    2. dunno
  3. Torven
    Root does currently check MR on ticks, but there is also a roll to check for that check. (charm is the same way) Level difference modifies effective resist levels, but you won't notice it much unless the level disparity is wide.
    Charm and root are using inherited EQEmu code, but I made some logs of both charm and root after I fixed a bug in the algorithm and the durations seemed acceptable. Much of the EQEmu resist code was already correct because a Sony dev posted some resist code pseudocode for their resist algorithm a few years back.
  4. Ravenwing
    Thanks, Torven!
    Thanks, Tollen. To clarify, though, are you saying that pets don't "mimic" their masters' resists at all here on TAKP (a la this patch, quoted below: http://www.tski.co.jp/baldio/patch/20020724.html), or that the pet "mimics" the master's unbuffed resist stats, then applies its own buffs?
  5. Tollen
    Tollen Member
    afaik pets don't mimic master stats in any way.
  6. Bum
    Mage pets can't directly since each pet has different special resist/immunity
    Air- mr
    Fire- fr
    Water- cr
    Earth- dr/pr
    Aside from that they "should" mimic
    https://forums.daybreakgames.com/eq/index.php?threads/do-player-stats-affect-pets.1148/
    From the July 24th, 2002 patch message:
    - Pet Resistance Changes: Pets will now use their master's level and
    resistances when saving against spells cast by NPCs (against PCs pets
    will use their own resistances and level as they always have) - unless
    the pet has special resistances, in which case it will use that
    resistance.
