Changelog 3-18-2015
Discussion in 'Changelog' started by robregen, Mar 18, 2015.
    * Client Push Support for CombatDamage_Struct
    * Removed manual push from Mob::Stun since it will be handled in the damage packets for the client and it caused too much jumping backward of clients due to latency between server and client.
    * Added some z adjustments so clients will not appear to bounce so much.
    * Improved z compensation for clients offset in LoS checks.
    * Line of sight should work better for casting spells.
    * Pets following owners will now use pathing nodes if they are available.
    * Pets will follow pathing (when available) while returning to their guard location following combat.
    * Fear on clients should work better.
    Database
    * Minotaurs in Steamfonts cave should now path.
    * Skellies should now appears around the Dragon Skeleton in Steamfonts.
    * Added Minotaur Sentry in Steamfonts
    * Barbarians in West Karana should no longer be perma-rooted.
    * Re-adjust loots for Kobold Predator in Soldungb
    * Fire giants should now have better drop rate and more coin drops in Soldungb
    * Pets (Beastlord, Shaman, Enchanter, Mage) have had their HP adjusted to be more in line with Torven's data and old data from archives.
    * removed the no drop sword from Guard McCluskey in WK.
    * added a missing recipe for Large Fine Steel Breastplate
    * Guard McCluskey and Guard Donlan should now take their destinated path at 5pm every night.
    * Add missing Human Culteral Armors Recipe as well as fixed the existing one.
    * Cyclops should now drops their loots in Rathe Mountains.
    * Added an undead knight, an undead bishop, and an undead rook in Butcherblock
    * Grendig in East Freeport should now drop his quest piece
    * Added a missing recipe for Enchanted dwarven plate gauntlets.
    * rearrange loots into the appropiate tables and added missing loots and Research table to the following zones.
    - North Karana
    - West Karana
    - Qeynos Hills
    - Rathe Mtn
    - Lake Rathe
    - Feerrott
    - Innothule
    - South Ro
    - Oasis
    * Default wizard NPC spell set: Supernova removed, Pillar of Frost added
    Scripts:
    * Fixed the questsay to Salinsa Delfdosan script when asking for a guantlet mold.
    * implemented the text flavor to Guard McCluskey, Guard Dohlan, Misty Storyswapper, and Sera McMannus
    * Added a missing return item plugins for Sultin.lua
    * moved random trigger spawn from minotaur_slaver.lua to a_minotaur_slaver.lua
    * added a missing quest dialog and reward to Dionna in Qeynos
