AK Lucy down
Discussion in 'General Discussion' started by Elrontaur, Sep 13, 2019.
  1. Elrontaur
    Anyone have access to Dwin's contact info? Domain is down.
  2. Haynar
    Pretty sure he has been emailed already.
  3. showstring
    have emailed dwin and sent him a PM on the forums
    however, his contact email is using the @alkabor.com domain, which is same domain as the domain that's suspended, so not sure if it will reach him...
    if someone has alternate contact details (discord, @gmail address, phone txt, etc), could you let him know
  4. showstring
  5. Elrontaur
    Wasn't Dwin in Temerity? Any Tem folks have contact info for him?
  6. Darchon
    I sent him a PM on Tem boards. I don't know if he checks them frequently
  7. Cadsuane
    He hasn't been on the Tem boards since 2017 :(
    I sent a PM and Email via the allakabor.com forums also, fingers crossed that it doesn't have the same suspended domain set there...
  8. bijaz
    bijaz Member
    The email on allakabor is from alkabor.com, so with the domain down he won't receive any notifications unless he actually logs into the site.
  9. Cadsuane
  10. sowislifesowislove
    So are we basically screwed unless we get in contact with this guy? Or needing someone to volunteer that has sweet internet skills?
  11. Mokli
    Someone might be able to use a local web archiver to pull it down from the way back machine or whatever its called, then host it elsewhere. Messed up and likely not kosher since no owner consent, but that is a massive amount of information down the tubes.
  12. Cadsuane
    I haven't looked into it, but I'd presume that while a web-scraper copy might be nice, the backend code is what we would really benefit from. We aren't 'screwed' without it by any means, but, it would be really nice to have.
  13. robregen
    This is just a frontend to read our spell file that is located in our client. Perhaps somebody can do something similar here.
  14. Haynar
    I have worked on something similar that was a stand alone app. Its easily doable. Just takes time to do the field translations.
  15. Cadsuane
    Right. Would be nice to not have to reimplement.
    I remember back in 2000 using a .exe that did the same thing, and pouring over the differences after each patch.
  16. Ravenwing
    Sounds like Dwin got it straightened out.
    robregen likes this.
  17. Sketchy
    Thanks for everyone who hunted this down and fixed it.
  18. showstring
    REJOICE!!!!!
    Manstache likes this.
