8-18-2021
Discussion in 'Changelog' started by robregen, Aug 18, 2021.
    * Added combat/pathing fixes for mobs in water.
    * Restricted the delta based projected client position changes to flee stuns.
    * Mobs should cross the bridges better in Siren's Grotto.
    * Mobs will fall below world less, when they cut corners of geometry.
    * The resist algorithm's roll is now using a > instead of a >=. This will make targets 0.5% more resisty.
    * Charm, root and blind spell tick saves now apply a +4 level modifier for the caster's level.
    * The charm and mez charisma modifier is now accurate and only applies to enchanters.
    * The preliminary rolls for charm, root, blind and fear spells are now accurate.
    * The default magic resist floor for charm was set to the accurate value.
    * The amount hate generated from charm spells has been reduced.
    * Animals now hate charmers as much as non-animals do on breaks.
    * Lull critical fail chance is now precise.
    * Charm and lull spells no longer have large resist penalties on yellow and red cons.
    * Quest NPC should now be able to hold more quest items up to 24 instead of 8.
    * vexthal: Eom caster NPCs may now drop items from TVX south's loot table.
    * Dire charms are now dispellable.
    * South Ro: Added a missing PH NPC "a mummy" to Ancient Cyclop spawn table.
    * South Ro: Lower case dervish cutthroat added to Ancient Cyclop spawn table.
    * South Ro: adjust the chances according to dev notes from Prathun.
    * Plane of Mischief: correct the turn in dialog for Vinny V. D`vicci.
    * Plane of Mischief: Vinny V. D`vicci will now correctly say the right dialog every 94 seconds.
    Pathing:
    * Fixed some bad pathing areas in Kael, The Hole, Siren's Grotto, Karnor's Castle and Cazic Thule.
    Sketchy, Manstache, Walex and 5 others like this.
  2. Faults
    Why did DC get changed? From what I read on ZAM its supposed to be un-dispellable
  3. Pithy
    From the Zam page, it looks like DC was dispellable for a long time, then got changed. For example, here's one Zam post:
    A quick search turned up a post from 2005 on the Druid's Grove called Dire Charm - No More Dispells!!!. It quotes Dev Maddoc via the Sony boards:
    So yeah, DC was dispellable from Luclin through DoDH.
  4. Faults
    Seems like the type of change meant to prevent griefing. Perhaps AKuracy isnt the way to go here.
  5. Savok
    Savok Active Member
    Well bye I guess to the last way for my bard to hold reasonable agro.
    Break likes this.
  6. showstring
    ok then, do we also need to change the following spell to also be dispellable: Complete Heal effect from Cleric Donal's BP, and also I guess Resurrections effects?
    any others?
  7. showstring
    yeah just checked my EQMac logs and found an entry
    [Tue Apr 09 18:26:17 2013] You begin casting Dominating Gaze.
    [Tue Apr 09 18:26:23 2013] You regain your concentration and continue your casting.
    [Tue Apr 09 18:26:23 2013] A brontotherium has been caught in a dominating gaze.
    some killing later
    [Tue Apr 09 18:43:00 2013] a Kromzek Captain has been slain by a brontotherium!
    [Tue Apr 09 18:43:00 2013] You gain party experience!!
    [Tue Apr 09 18:43:06 2013] You begin casting Pillage Enchantment.
    [Tue Apr 09 18:43:09 2013] Your charm spell has worn off.
    [Tue Apr 09 18:43:09 2013] A brontotherium feels very dispelled.
  8. Break
    The water pathing seems much improved in the small areas of Siren's Grotto where I have fought underwater. I haven't been near the bridges. Thanks for the fix.
