7-21-2014
Discussion in 'Changelog' started by robregen, Jul 21, 2014.
    Set Aviaks in Rathe Mountain to respawn 6 mins.
    added a spellset for Froglok Warden to invisible upon spawn.
    added Cuburt to database for qeynos cata.
    set Tae Ew mobs in Feerrott to respawn 9 mins and 35 sec.
    Reduced ac values to mage pets.
    increase spawn chance to various named mobs in SolA, Upper Guk, and lower Guk.
    * Removed unused login code.
    * Added an account activate setting.
    * Added activation check to allow/disallow per account logins.
    * Corrected the spell scribing related item desyncs.
    You will now receive a warning in a case where the server feels you may have desynced (or are about to), but haven't yet desynced client side. This message *should* only occur on the Intel client. But if it does happen on PC client, please report it. Also, I'd welcome discussion on the forums of any patterns that you may see when this message occurs. I have a sneaky suspicion that the longer you are in a zone for, the less likely you are to see this message. Also, I believe the faster you move items around, the more likely you are to see it. For reference, the message is in yellow and is:
    "Caution: You may have de-synced. Stop what you're doing, and log out now to avoid item loss."
    * Changed some desync logging to make it easier to spot true errors.
