7-10-2019
Discussion in 'Changelog' started by robregen, Jul 10, 2019.
    * Added additional checks to help prevent groups and raids from being bugged. Sometimes when someone gets disconnected zoning, they will skip the linkdead cycle. And the server allows them to login right away. In these cases, they will go back in the raid/group without bugging out better.
    * Made some changes for zoning, to try and help with the super long zone times.
    * Reduced some of the max packet sending rates to the client, to help prevent routers from disconnecting on massive packet situations like when doing AOE.
    * Identical bard songs from two bards, with different instrument modifiers should land better.
    * Started work on pre-calculation of some spell properties which are checked often in code, to reduce cpu in the busy spell casting code.
    * Fixed a spell logging message that was missing a parameter.
    * Tinkering is no longer restricted to gnome. Only gnome can raise skills with Tinkering.
  2. Kuron
    Kuron People Like Me
    And a stealth change: adding blue diamond recipes.... right? :D
  3. Walex
    Omg. Didn't even know this was being worked on. Thanks Haynar!
    gardnerjens likes this.
  4. Haynar
    See if it helps you. I have varied it over the years.
  5. showstring
    Just had two clients crash zoning from my home PC, this never happened before.
    Three boxing:
    Char1: Rimidal, crashed zoning into The Grey, other two chars fine
    Char2: Borat, zoned into Ssra fine
    Char3: Swag, crashed zoning into Ssra
    attached is dbg.txt file
    http://s000.tinyupload.com/index.php?file_id=20140445386959898644
  6. showstring
  7. showstring
    Heh, I logged Rimidal in about 1.5 hours later after this, and was still in group with Swag
  8. Slayzz
    Ya it’s weird it’s not like a normal LD where you can’t log back in right away. Now you can immediately log back in the second you DC and when you do you’ll still be in the same group etc
  9. srubin
    srubin Member
    Also crashed zoning into the gray. Could log back in immediately and remained in group!
  10. Dane
    Dane People Like Me
    Experiencing this as well.
  11. Haynar
    Patch notes already said disconnecting zoning will put you back in group. Rather than bugging group.
    The new issue is people getting disconnected zoning more.
  12. Mokli
    Thank you for that feature btw Haynar. It is pretty much what they did on live a while ago to try to deal with broken groups from LD's. I always liked it.
  13. Haynar
    Hopefully patch fixes going LD zoning thats going on. I have tried many times to fix bugging groups/raids. Then i gave up on that rare case, trying to remove them. Since i found a way to repeat it. What other way to prevent bugging? Well. Put them back in the group/raid. And it worked.
    Still needs some tweaks. But way better now.
  14. showstring
    Already excited about 72+ man PoTime raids, thanks Haynar
  15. Darchon
    PoTime kicked the 73rd player to zone in even when it was a static zone. 72 will be the maximum in that zone and you will like it!
    Quirk likes this.
  16. sowislifesowislove
    Was stuck in a bugged group for 10 minutes tonight. Tried to religiously several times, no luck. Couldn’t join group for port or my raid. Was really annoying. I think zoning then disbanding fixed it but while in same zone bugged I couldn’t do anything to get out of group.
  17. sowislifesowislove
  18. showstring
    Still having troubles with this. Unable to overwrite same songs with different instrument mods, even in cases where I try to over-write it with a higher instrument mod, and even when second bard has Jamfest and first bard doesn't.
    problematic songs:
    http://lucy.alkabor.com/spell_1758.html - Selo`s Assonant Strane
    http://lucy.alkabor.com/spell_1764.html - Denon`s Bereavement
    Also, getting a lot of "did not take hold" messages when I try to use http://lucy.alkabor.com/spell_2609.html - Chorus of Replenishment, it seems to be trying to hit mobs or something? even when I'm the only person nearby I get "did not take hold" message (sometimes multiples), assuming it's from the nearby mobs, or maybe invisible traps or something....
  19. Cadsuane
    Chorus is giving that message from hitting pets,I believe.
  20. Faults
    It give sthat message from hitting mobs too
  21. Walex
