2-17-2021
Discussion in 'Changelog' started by robregen, Feb 17, 2021.
    * attempt to fix buff display desync when a regular buff overwrites a bard song buff
    * allow melee disciplines to work while invulnerable
    * adjusted melee disciplines:
    ~ reuse timer reduction added for levels beyond 60
    ~ thunderkick base reuse changed from 420 to 540 seconds
    ~ silentfist base reuse changed from 540 to 594 seconds
    ~ reuse timers are reduced by 54 seconds per level (down from 60 seconds per level)
    ~ reuse timer can't become less than 234 seconds (up from 60 seconds)
    ~ allow disciplines to be used while stunned
    ~ allow disciplines to be used while invulnerable (divine aura, harmshield, etc)
    Secret
    * Fix issue with dueling where accepting one could result in a nullptr zone crash
    * Also fix duel 'ownership' flags to not be able to be spoofed maliciously
    * gukbottom: Raster of Guk spawn chance reduced.
    * Crushbone: replace pathing with Random Path to make it more live like.
    * Recipe: Enchanted Cazicite Bar is now a no fail combine
    * Recipe: Correct trivial skill with Unfired Sealed Poison Vial using Low Quality Lion Skin to 219
    * Trakanon: Correct NPC name "Trakanasaur Rex" to "Trakanasaurus Rex"
    * item: Rose of Firiona should now be unstackable.
    Mechaike, Thunderace, Aithne and 6 others like this.
  2. Cadsuane
    Thanks for the work devs!
  3. Kriptik
    Kriptik New Member
    is there an issue with Duels? twice now in two different zones after relogging both toons, i couldn't accept a duel. Both charactesrs just say "you have challenged CHARACTER to duel to the death"
    It happened in Mons Letalis and Plane of Hate. First time i thought nothing of it and just ran back to pok
  4. robregen
    oh I forgot to mention in this patch. I updated the patchnote above:
    Secrets
  5. robregen
    looks like a bug from the duel 'ownership'
  6. Mokli
    That's a pretty big nuisance. A good number of raiders in zones like ST will duel others to get out.
  7. robregen
    it'll be fixed for next patch.
  8. Sketchy
    Gate potions, TL's, ports, lots of ways out. Mild annoyance but it will be fixed so eh.
  9. Mokli
    Yep, what I mean is it will be a problem for anyone that doesn't know. I guess we'll just have to announce at our raids.
  10. Cadsuane
    You have raiders that don't read patchnotes and forums? That's half the fun!
    Ripwind likes this.
  11. sowislifesowislove
    Thanks for the work devs. Ouch, two weeks without dueling is a major pain.
  12. Darchon
    Fun bard bug!
    Currently if you have KEI on you can refresh KEI (normal behavior). KEI stacks with Lcea/Chorus of Replenishment (bard AE mana/HP regen songs) also normal behavior.
    However as of this patch, if you have KEI and Lcea on your buff bar, you cannot refresh KEI. Or even if you only have Lcea, it is blocking KEI from landing.
    Lyrina likes this.
  13. solar
    Hmm yea I was afraid something like that would happen if I mess with it. Thanks Darchon.
  14. GreldorEQ
    GreldorEQ Active Member
    Frostreaver's Blessing from ring10 is also blocked by Chorus of replensihment - you can have both, just have to have ring effect on before bard song starts - also seems that all clarity line spells are affected, not just KEI.
  15. GreldorEQ
    SP does not appear to be blocked by Chorus, nor Lunar Whispers, nor Regrowth of the Grove.
  16. kai4785
    Re: Bard stacking
    http://www.afterlifeguild.org/Thott/haste_stacking.php
    I am under the impression this was written in the Kunark era. I'd prefer to find an actual dev quote, but Thott is all I can come up with. While the article is all about bard haste, he had this to say:
    Today's behavior seems to be *that* behavior. I can't say I *like* the new behavior, but it does sound just like what Thott is describing here. What would be Ak'urate?
    It seems to me that the exception for bard songs should work both ways, not just in one direction. Meaning, bard songs should stack on top of other spells, but also other spells that are stronger than bard song, should stack on top of spells. But I don't know anything about how the code works, and if that information is even available at the time a spell like KEI tries to land.
  17. solar
    I fixed the desync with the double aego but it seems to have caused other changes.
  18. Polly
    Polly Member
    Probably the same reasons for Lcea blocking KEI, but adding that Lcea also blocks Regrowth of the Grove.
  19. Soreloft
    Soreloft Member
    Just as a heads up, following this update it seems as though the warrior Defensive discipline has been reduced from 3 minutes to 2.5 minutes.
  20. Ripwind
    Ripwind People Like Me
    Hmm, I'm not seeing that.
    [Mon Mar 08 14:09:43 2021] You assume a defensive fighting style.
    [Mon Mar 08 14:12:43 2021] You return to your normal fighting style.
  21. Soreloft
    Soreloft Member
    My mistake. I'm an idiot.
    I was looking at the time left to reuse the discipline. It now reports 7.5 minutes before it can be used again because the reuse timer has increased, not because the discipline has a shorter duration.
    Ripwind likes this.
