12-12-2018
Discussion in 'Changelog' started by robregen, Dec 12, 2018.
    * NPC AI will now cast heals while chasing players.
    * NPC spellcast AI will now cast detrimental spells a bit more aggressively.
    * Lifeburn now takes the caster down to 20% hp instead of 10 hp.
    * New database fields were added to allow NPCs to have individual experience multipliers and bonus avoidance.
    * Undead/proximity aggro NPCs are no longer restricted to melee range when seeking targets that are not the tank.
    * Significant additions to Haynar's anti mass-kiting logic.
    * Add initial code which limits kite/train sizes.
    * Pathing updates.
    * Factions: Factions throughout Norrath including Kunark, Velious, and Luclin has been adjusted to be more accurate.
    * Ocean of Tears: Added a missing NPC "a greater skeleton"
    * Ocean of Tears: a gargoyle and a greater skeleton will now aggro on each other when close in range.
    * Ocean of Tears: added a missing pathgrid to a gargoyle and a greater skeleton.
    * Ocean of Tears: AC and it's PH will now roam the island.
    * Game command: disabled #loc
    * templeveeshan: Symbol drake respawns are now 7 days +/-12 hours.
    * veeshan: 25% experience bonus applied to non-dragon NPCs which brings their exp gains more in-line with log data.
    * vexthal: Small avoidance bonus applied to most boss NPCs.
    * Ak'Anon: Windlebeck Tobokog should now accept the parchment and give out the kit as the reward.
    * vexthal: The TVX encounters have been modified in an attempt to mimic behavior observed on Al'Kabor.
    Harakiri
    * Lomarc Already uses a Death Emote from DB
    * Beek_Guinders Fixed Faction Reward for Gather Quest
    * Lars McMannus Added missing Text Triggers
    * a hermit Fixed Faction Reward for Winds of Karana sheet 1
    * Rueppy Kutpruse Added Faction Check for stout Quest
    * Sir Morgan Add missing dialogue and message for turning in the wrong amount of gold/item
    * Squire Wimbley Add dialogue
    * Sir Morgan Fixed Reward, was giving out Sonic Wolf Claw Earring instead of Drom's Champagne
    * Uner Gnarltrunk Deputy Tagil's Debt Quest - Added Faction Check and Fixed Faction Reward
    * Beek Guinders Adjusted Faction and coin Reward for Cleric Supplies Quest
    * Toelia Snuckery The Torn Pouch Chomper Quest added Faction Checks and Fixed Faction Reward
    * Silna Songsmith Fixed Mail Quest text to indicate the correct person to deliver to.
    * Felisity Starbright Fixed Faction Reward for Mail Quest Fixed Message for Mail Quest
    * Deputy Eigon Added Hail Trigger Fixed excessive Cash Reward
    * Marshal Anrey Added Faction check for Leatherfood Raider Quest
    * Xelha Nevagon: Added missing faction based text/corrected reward text and added rewards. Increased faction requirement for cyclops eye to kindly. Improved xp and coin reward.
    * Gren Frikniller: Fixed Faction Reward for Broken Heirloom turnin
    * Sir Lucan D-Lere - Add correct turn in message for traitor quest, fix faction rewards for traitor and messenger intercept quest and add money rewards
    Mechaike, Lyrina, Elroz and 1 other person like this.
  2. Thunderace
    Thunderace People Like Me
    Why change the hot drakes to 7 days from 3?
  3. Thunderace
    Curious to see the pathing changes
  4. thefrayman
    thefrayman New Member
    Thank you so much for fixing the faction issues! I was starting to thing I was insane. I checked a few and they are much better now. =)
    Manstache likes this.
  5. Torven
    Because I found hard evidence that they were 7 days
  6. Thunderace
  7. nworbetan
    nworbetan Member
    Is the pathing fix still a work in progress? I've seen a couple mobs whose pathing issues weren't fixed by this update. I didn't report them because there were already multiple reports of nearly identical issues and I waited to see if the generalized fix in this patch would take care of it. Would another bug report be useful at this point?
  8. Lenas
    Anything you encountered after this changelog date, yes, please report. As specifically as you can.
  9. showstring
    Ramps still having issues. Here is a video recorded in plane of hate on dev server
  10. Bum
    Certain zones I have enabled traps to keep people away from my farmlands.
    You're welcome
    pharmakos likes this.
  11. Placer
    Placer Well-Known Member
    FWIW, only the burrower in AC was more than a 7 day spawn. Near anything 7 days was actually 6 + 0-24 hours.
