Updated client on user wiki
Discussion in 'General Discussion' started by robregen, Dec 31, 2017.
    Linkamus, Gnazzles and Ransom like this.
  2. Draeko
    Draeko Active Member
    Is there a list of the updated files compared to the old one? So then we can just copy/replace the new stuff in without having to remake a client file
  3. Haynar
    No there isnt. Since there were so many different combinations of client/dll, eqw, etc., this would not be trivial to do.
    I personally used the installer. And copied my char files over to the new folder. Then done.
  4. Draeko
    It's way more complicated than that for me with 3 installs, a UI with a couple windows taken from other ones, etc.
    Could you point me to just the BST MGB files please?
  5. Cadsuane
    Everybody wants to be a power user until it's time to do power user stuff ;)
    I'd recommend that you back up your current config, download BeyondCompare, and start merging your settings into the new install. There isn't anything as simple as an mgb file(s), it's in the executable.
    Speedz and Lenas like this.
  6. Torven
    A list of MD5 hashes for every file in the archive is provided on the wiki. You can use a tool like MD5summer or FileVerifier++ to determine which files have been added or modified. This is harder and more time consuming than simply copying over ini files and your UI folders over into a new install, though.
    Speedz and Cadsuane like this.
  7. Haynar
    Its in eqgame.dll
    https://www.dropbox.com/s/bsghqdkqhwmsido/eqgame.dll?dl=0
    Thats set up for using with latest client build. Its not tested with older client setups.
    Draeko likes this.
  8. Draeko
    Looks like the new .dll works. I have most every update of yours except free the mouse
  9. Bum
    Instead of working on crappy pc versions, let's see the new iOS one!
  10. robregen
    the new sky.s3d file works on the intel client. I just tested it.
  11. Draeko
    Added that too, you can almost see the space cats if you squint
  12. Sketchy
    Thanks for providing this client update guys, it's great to have such a comprehensive package to use.
  13. Bum
