How do mounts work here?
Discussion in 'General Discussion' started by numinari, May 6, 2020.
  1. numinari
    numinari Member
    I am assuming they need luclin models to be on? Out of curiosity. I like the Luclin models, just kind of oscillating between them and the classic ones. They both have their merits.
  2. Devour_Souls
    Luclin models must be on to mount the horse and use its movement rate. While mounted, the character is always meditating when not moving or when not casting. (Also melee??)
    If you turn all "new" models off you will be able to summon the horse buff icon and meditate while standing. The movement and casting restrictions still apply and you get no movement rate changes from the horse buff.
  3. numinari
    numinari Member
    Awesome, that is exactly what I wanted to know! Very cool, that is how I remembered it on live as well during pop.
    +1 for the detailed explanation.
  4. Mokli
    To do that, you need this setting in the ini: AllLuclinPcModelsOff=TRUE - This disables Luclin models. This also allows use of the famous horse bug that existed on AK where you don't have the limitations of horse speed up/down that you do with Luclin models on.
    numinari likes this.
  5. numinari
    numinari Member
    Thank you very much for the heads up and the ini edit line!!!
