Fine Antique Ring in PoK
Discussion in 'General Discussion' started by Elrontaur, Nov 18, 2014.
  1. Elrontaur
    The quest Holly Longtail's Replacement Parts in PoK is unfinishable due to the cockatrice beak not being available till Kunark.
  2. Elrontaur
    Re: Fine Antique Ring
    Also, the HQ Cougar Skin is only available in Velious.
  3. Placer
    Placer Well-Known Member
    Yeah, sadly the POP quests wont be available for a while except for the Traveler's manual. That's all tested and works fine because it is all contained inside the zone. Great lightsource!
  4. Yinn Yang
    Yinn Yang People Like Me
    Speaking of lightsource, I haven't noticed any effect coming from any lightsources. However, I also noticed my human monk isn't as nightblind as I had recalled humans being. I've equipped lightstones, GLS, Split Paw mask and a couple of other lightsources and seen no change... is it just me? Is anyone else having this issues? Or do I have some setting configured incorrectly?
  5. Sketchy
    I have 2 nightblind chars here on the server, using the PC client. There is a setting in the options when you first open the client, its called dynamic lighting. I think it is turned off by default. So make sure that is turned on. Lightsources/darkness are pretty classic thanks to this version of the client.
  6. Yinn Yang
    Very cool, that sounds like the issue... will check it when I get home. Thanks!
