Faction values here vs. Allakhazam
Discussion in 'General Discussion' started by Kuron, Oct 29, 2020.
  1. Kuron
    Kuron People Like Me
    Are the values listed on Allakhazam for faction hits on kills/quests typically "close" to what we have here, or are they so far away from the mark that I shouldn't even pay them any mind?
    Just curious!
  2. showstring
    usually not accurate
    just test it on dev with new command #viewplayerfaction [factionid]
    factionid is a number you can retrieve for desired faction by targeting an npc on that faction, and once you know the number of the faction, you can type the command in any zone (don't need to target the npc if you type in the number instead)
    example #viewplayerfaction 430 is to check claws of veeshan faction
    so, go to kael, kill a mob, type the above command, kill another mob, type the command again, check the number difference, and so on
    Sketchy and Mascha like this.
  3. Kuron
    Thank you, Rimmydingdong!
  4. Neealana
    If anyone remembers Jerumiah from AK, this was one of the things he worked on A LOT on P99. Getting the factions right in the code ( or better )
  5. Lenas
    I'm pretty sure Rob has verified a lot of our faction values on live since they report them directly now.
  6. robregen
    yes that is right. I have done a lot of verification from live with kill and quests. Not sure about ZAM and how they got it verified.
  7. Palarran
    Palarran Well-Known Member
    Allakhazam's values should come from those same Live reports, so I would expect them to generally match (at least for quests where Allakhazam has faction values listed)?
