Boxing Three Rogues - Can it be done?
Discussion in 'General Discussion' started by Szev_Nightshade, Jun 25, 2019.
Tags:
  1. Szev_Nightshade
    Szev_Nightshade New Member
    It's an odd question I know, but I simply love the rogue class and I wonder what the pros and cons are of this particularly box. I would want to setup Hotkeynet 101 for sure, but I am simply looking for feedback as to how I could make a box like this work. I figured I would try it out and see what happens but I'm curious if others have attempted anything like this or have any tips of how to successfully navigate boxing three melees.
    Perhaps an altnerative would be to go Cleric/Rogue/Rogue or Shaman/Rogue/Rogue though I am curious as to what the difficulties of three rogues would be from the start. Certainly some camps would be closed off to me (and I don't know whether sneak-pull works here). There is always the potential to simply group up with others on the server with this trio too. Any advice people could offer would be most welcome!
    -Szev, Brin, & Tvinn
  2. Linkamus
    Sure, it can be done, just make sure to level up bind wound, haha. Shaman / rogue / rogue would be a lot less painful.
  3. Cadsuane
    Clr/Ench/Rogue would work also. Cleric and rogue can switch off tanking slowed things, you get the desired buffs / pacify / CC, and could charm too.
    or Clr/BL/Rogue
  4. Tuluvien
    Sham/rogue/rogue would be fun. Tank and slow on sham. Self healing. Double the backstabs
  5. gardnerjens
    i have done 3 times rogue, its not that hard on raids but anyoing if you dont have a group. and your team dont place the mob in the same spot all the time
  6. Tuluvien
    What haven't you done 3 of? Haha
  7. Tryfan
    Tabbing to backstab every couple seconds will make you want to kill yourself.
    If you had three computers, it might be more interesting.
  8. Manstache
    Manstache Active Member
    give the rogue powerups with a shaman and a beastlord! :)
    no pac though
  9. lurari
    Berserker.
    Ripwind and gardnerjens like this.
  10. Szev_Nightshade
    Thanks for your thoughts on this, all. I used my level 20 mage to continually DMG-shield two of my three rogues. Switching between the two rogues (and just having my mage auto-follow) has been a lot of fun. I tried dropping in a shaman to level with the two rogues but it just seemed like a lot more clicking between screens than I thought shammy would be. I am beginning to think that I might continue with Rogue/Rogue/Magician (once the two are high enough to group with mage) not just for damage shield, utility spells (summon bandages, arrows, etc.), but also added DPS from mage pet. The saga continues.
    --Szev, Brin, & Tvinn
  11. Morbo
    Morbo Well-Known Member
    Boxing 3 rogues is incredibly easy. Boxing 3 rogues to level up is incredibly tedious.
  12. elessin
    elessin New Member
    y tho
    Morbo, lurari and Manstache like this.
