8-31-2022
Discussion in 'Changelog' started by robregen, Aug 31, 2022.
    * Corrected an error in the combat skill-up logic that was resulting in combat skill raises becoming slower after 135 skill stat value.
    * Cleric NPCs will now cast dispels less frequently.
    * Summoned pets were previously not gaining AC from the armor they were wearing or from buffs and this is now working.
    * Added a pre-navmesh change which is contributing to current excess LDs.
    * Added a fix to help prevent groups/raids from getting bugged when a player goes LD while zoning.
    * Removed out of era GoD Learned Recipe codes from Tradeskill.
    * tweak range attack distance calculation to avoid the situation where it still uses up ammo when out of range
    * meditate skill no longer improves while already full mana
    * Added a few missing items from Elroz's missing items list.
    * Padded Tigerskin Gloves should now show the worn effect.
    * Elemental Sheet combines for Molten Ore, Immaculate Steel, and Wind Metal should now require 2 Ores/Metal to make and produce 1 Sheet.
    * Skill patch (partial) More work is needed but this patch adjusts some of the incorrect logic around cap values.
    ==== Paladins get Bash at level 6
    ==== Paladins get Parry at level 17
    ==== Rogues get Intimidation at level 22
    ==== These 3 class/skill combinations were acting bugged before those required levels.
    ==== Here are the differences for level 65 characters.
    ==== There are a lot of changes for the intermediate levels so I won't list that out.
    ==== Cleric Bind Wound 201 -> 210
    ==== Cleric Bash 200 -> 165
    ==== Paladin Channeling 220 -> 215
    ==== Paladin Meditate 235 -> 226
    ==== Ranger Riposte 150 -> 185
    ==== Shadow Knight Channeling 220 -> 215
    ==== Shadow Knight Offense 230 -> 225
    ==== Druid Bind Wound 200 -> 210
    ==== Monk Block 230 -> 225
    ==== Bard Dual Wield 210 -> 245
    ==== Rogue Double Attack 240 -> 245
    ==== Shaman Bind Wound 200 -> 210
    ==== Shaman Alchemy 180 -> 200
    ==== Beastlord Channeling 220 -> 215
    ==== Beastlord Meditate 235 -> 226
    ==== Beastlord Throwing 118 -> 113
    * Fixed up Trooper Dialogues in/around cabilis
    * Went through each epic quest and fixed/added minor things (Partial Hand-in Texts, typos etc).
    * Added/updated dialogues to some WW Dragons, Kland, Zland, Jaled Dar etc.
    Break, Manstache, Cadsuane and 8 others like this.
  2. Baptie
    Baptie Member
    Ripwind and Tuluvien like this.
  3. Smudge
    Monks were deemed to be tanking too well.
    Ripwind, jbry2, Kithani and 1 other person like this.
  4. Nemce
    Nemce Active Member
    I watched one of our monks block, parry, dodge and otherwise juke Quarm last night for a solid 30 seconds without taking damage. Guess we gotta switch up our monk tank strats.
  5. Baptie
    Baptie Member
    Yes, of course!
  6. Barnd0g
    Barnd0g People Like Me
    Need to lower monk ac also imo
  7. Tryfan
    If Haynar's fixes work I am voting for him as King.
  8. Elroz
    rob didn't mention it in the patch notes but he updated the alla clone too
    showstring and Mokli like this.
  9. Braven
    Braven Well-Known Member
    It should be noted that, according to the formula I know, the above change will not affect block chance for Monks at max level, but will just require a 8% mod to get an additional percent chance rather than the previous 7% mod needed. In other words, MASSIVE SLAP TO THE FACE.
  10. Nakunaru
    Nakunaru People Like Me
    Drudger completely unplayable now. Time to reroll.
  11. solar
    Doubt you guys would have noticed these minor changes if it wasn't posted. Mostly it was about fixing the lower level progression of skills (they're not all 5 per level).
  12. Smudge
    Good thing Time BP is 8% mod then I guess.
  13. Mardark
    Mardark Member
    Are there any 7% mods?
  14. Smudge
    Only other mod I see is 5% from Caen's Bo Staff which wasn't doing anything anyway according to Braven.
  15. showstring
    Great patch, thank you! Got my fingers crossed for the LDs/crashes hopefully being better on raids, a girl can dream.
    Is this fix for crashing on zoning? Or just some other LDs? Sorry wasn't clear
  16. showstring
    Let's not encourage this sort of behaviour please. Can we roll it back?
    Or ideally just set Dual Weild skill to 1 for bards like it's supposed to be?
    Ripwind, Linkamus and Cadsuane like this.
  17. Tyrion
    Tyrion Well-Known Member
    Pretty sure golems and draco are supposed to be up after reset and they weren't as i checked first thing. Mayhaps reset didn't function as intended?
  18. robregen
    oops I forgot to reset the spawn.
    Aithne likes this.
  19. Tryfan
    The linkdeaths do not appear to be fixed.
  20. showstring
    correction: they appear to be much worse
    crashing every time now
  21. snorks
    snorks Well-Known Member
    Got quadded on a pull of a trash mob yesterday for 4x max DI
  22. Burfoot
    Burfoot New Member
    I was wondering about that exact point Braven referenced. There's a 10% block bracer from GE. So that should still have the same level of increase it did before with respect to actually modifying the chance to block.
  23. actualspaide
    Man with this change i should get a weapon
    Ripwind and Walex like this.
  24. shorttin
    shorttin Member
    +1 for this. I would very rarely crash prior to the patch when large numbers of people would but last night was pretty bad even for me.
  25. Caeadarie
    Caeadarie New Member
    Crashing on camping, zoning, rezzes. I even crashed after a rezz and looted.
    also still having the group bug, but I can normally disband on someone and get them back in the group and make them leader and re-invite the LD person.
