Code Solar * remove a redundant MovePC for airplane, client does this on its own * minor cleanup to clamp some out of range position delta values * clean up/rename/reorganize rdplib files and function organization, recovered some original symbol names * add rdplib socket buffer tuning, treat socket send buffer exhaustion as backpressure * request larger system socket buffers for rdp server endpoint * restore client driven type 57 teleport doors - soltemple is accessible again by walking into the pink objects * restored a few KEG door objects in steamfont and misty * allow door scripts to suppress native handling * fix world TCP listener startup error handling * suppress invalid spawn deletes * improve logging and report RDP connection diagnostics Scripts Solar * correct a MovePC heading in a potactics script * fix an in-combat rez exemption heuristics in potimeb to account for the recently reworked rez effects TAKP TLP only reworked all the netcode and zoning/death/etc for TLP like in the previous patch for TAKP so they're logically in sync
