Code: Torven: * Fear spell resist chance is no longer modified by the charisma statistic. * The extra rounds from Flurry and Rampage no longer quad if the NPC is not dual wielding. * Archery exploit check now only applies to NPCs with an ignore distance >= 350. solar: * instant clickies will once again not have a casting message when they begin casting * MGB buffs will not hit pets anymore, only players * MGB will no longer function on item clickies or auto cast recourse spells Haynar: * Changed some of the LoS methods for transitioning between node and non-node areas. * Fixed and issue with quiver haste that resulted in increasing bow proc rates excessively. Database: Torven: * fungusgrove: several common NPCs have had their statistics altered. * akheva: The Insanity Crawler has been tuned. * akheva: a rubble rouser spawn time reduced to 4 minutes. * akheva: several common NPCs have had their statistics altered. * akheva: Shopkeeper Shei's stats adjusted downward. * akheva: Respawn time on NPCs in Shei's room increased significantly. * ssratemple: High Priest guard respawn timers are now much more accurate. * ssratemple: Spell: Remove Greater Curse drop chance increased. * shadeweaver: The swirling shadows farm region implemented. * lakeofillomen: Sarnak courier spawns are now much more like AK/Live. Robregen * The Grey: Xakra Sei and a Xakra Shah are now flagged as animals. * Jaggedpine Forest: Yranik Blackguard and Vaurien Sticklebush should now aggro within range. Quest: Torven: * Xin mobs will now be spawnable when dying to Shei Vinitras' vendor form. * Shei Vinitras Tatrua guards now respawn every five minutes or so if killed. * Shei Vinitras cumulative unaggro depop timer is now 15 minutes. Misc: Haynar * Maiden's Eye: Path around AR should improved.
* akheva: The Insanity Crawler has been tuned. We tried to spawn this guy last night but couldn’t figure out the mechanic. Any insight into how he spawns?
Yeah, I've probably seen about 500 zone reconnect messages in the last hour. Something is very wrong!
He spawns on his own. The zone does an emote/message when he spawns. Currently we have him at a 3 day spawn because of Alla comments, but this could be wrong. (even likely wrong) Hard to know what it should be when Live can't be used for respawn timers.
Interesting I’d heard it was a trap or some combination of killing worms. Does he despawn once he has been spawned?
He was a 2 day spawn on AK I'm fairly sure - I killed VD every time I could because I enjoyed that I could - and I recall IC being 2 days because someone in destiny (gnostica? darco?) was always pestering me to check as I ran through (Wild? Briarthorn? - one of em)
