Code: Solar * adjust bard logic for first spell slot * Warrior AA Warcry fixed so it works in raids and affects group members within 100 range of the warrior * remove minor illusion when player moves. this is a workaround for when there are no objects nearby to transform into. * add 'did not take hold' message for AA spells Robregen * some refactoring with renaming variables involving slots. * fixed an appearance issue when charming a npc in sitting or lying position. * add a couple of condition for zones not idling. Database: Torven * kael: Both 'protector of zek' NPCs are now charmable. Robregen * Fiend Gut String should no longer stack. * Putrescent Blood should no longer stack. Script: Elroz * Quests update for East/North/West Karana, Qeynos North/South, Qeynos Catacombs, Qeynos Hills, and Surefall Glade. (Dialogues, Min. Faction Requirements, Hand-in Text, Rewards etc.)
Rimi posted a trick to unstack them, somewhere. I presume you'd have to post a petition if it doesn't work for you.
even with the trick. it should post a bug so the item itself should be fixed so the trick would not be needed.
