7-29-2026
Discussion in 'Changelog' started by robregen, Jul 29, 2026.
    * remove unused EQStream and related infrastructure. this was used to detect and switch between the older style rdp transport and the newer one but this code is not used by the TAKP client and it had a bunch of validation errors that could be used to crash the server. this code was reachable by pretending to be a newer stream type but this normally didn't happen with the clients we actually use so it was old rotted code that ended up getting exploited.
    * rewrite netcode for UCS
    - Fix reliable packet fragmentation, reassembly, and packet-size accounting
    - Improve ACK handling, retransmission, sequence rollover, and send-window flow control
    - Correct CRC, compression, XOR, and combined-packet processing
    - Harden session negotiation, malformed packet handling, and disconnect behavior
    - Add configurable UCS connection limits and legacy channel tuning
    * TLP: Fixed issue with classic resists associated with enchanter NPCs.
    Sketchy, lurari, Pithy and 5 others like this.
  2. showstring
    bard songs are spamming me and I have bard songs turned off (set to Group only)
    this only started happening very recently
    few guildies are also complaining, don't seem to be able to filter it out
    did something change?
  3. showstring
    whole dang chat is just bard songs ending now
    anyone able to turn it off? only started happening since the patch
