Code: * Changes to InterruptSpell to correct some messages. * Decreased failure chance for FD. * Removed the message when your hate list is cleared due to FD. * FD will now be broken when a detrimental spell is cast on you. * Added see invis to #showstats * InvisVs Undead and Animal will no longer set an invisible flag. * You can now lifetap Eye of Zomm. * Defense skillups should now be more in line with the other defensive skills. * Removed unused code. * Removed modern PVP codes. * Updated text color defines and set many messages to use those, instead of non-descriptive numbers. * Fixed an item desync. * Implemented Hawk Eye family of spells. Database: * Changed the respawn timer for Cazel to spawn between 2 to 24 hours. * Set Cazel's spoon drop to 100%. * Added Hatar to Oasis DB. * Adjust Ashten Order faction. * Adjust the Silent Clan faction. * Fixed a door and drawbridge in Sol A. * Generated new loottables for Ogres at the Orge camp in West Karana. * Fixed the vendors in Sol A. so it no longer shows a blank first slot. Script: * Fixed Phin Esrinap script in Qeynos2. * Fixed Geeda scriptin Gfaydark.
