So thanks for this, it seems much better than it was but still getting weird stuff in chardok an iksar collaborator will not go below the waters surface when charmed or not and can't be hit or cast on by non pets. Some mobs get stuck in walls so really have to coax them out or coth and try again.
I know I had issues with some corners last night in ToV. Mainly because mobs could go past me on some walls.
I was working on water/land transitions while mobs are moving. Shouldn't have had anything to do with corner tanking.
That was the first time in ToV since the overall patch, so could have happened then or any of the hotfixes after.
Mobs are warping up into walls now above the players. Was AEing velks by pulling mobs to zone line, and mobs would get stuck up walls / flicker up above you and below you / summon you into the walls up above. Very messed up. Affected the golem mobs the most, but was happening for dogs and gargoyles too. Spiders seem to be fine.
here are some screenshots from velks the people that died had their corpses up in the air where the mobs warped to screenshot 1: getting rezzed up in mid air (took screenshot asap) http://magaimg.net/img/3xsb.jpg screenshot 2: falling damage after rez http://magaimg.net/img/3xsi.jpg screenshot 3: loc of problematic spot and you can see my char is half way through the wall http://magaimg.net/img/3xsu.jpg
agro mobs from castle, run to zone in area, wait in corner for mobs to come to you, pbae stun push into corner (each pbae has small push forward) they should glitch out and start warping up and bum, why would you pursue any other exp other than pbae exp? pbae exp is going to be the norm until PoP
also this spell will help: lvl 34 mage pbae nuke Thunderclap http://lucy.alkabor.com/spell_471.html has a pushback of 10 units, useful for pushing mobs into the corner to group them up
We AEd Velks some a few days ago without any issues. Have you tried a different corner? May just be that one spot? Just spitballing...
different corner is fine, we carried on by not pushing mobs into that corner for now but this is a new-ish issue, first occurred few weeks ago, and happened again today
Also a new bug: Now if you agro Undertow or his ph "swirlspine seahorse" and swim down to pull him to the bottom south west corner of the area, he will not follow you properly, but instead attack you from somewhere up above you in the z-axis in the floor above or something. You can't attack him, but he can attack you. Have to swim back to the room he's in so he pops back out of the wall, then make him swim down a little so he's not above the roof of the room, then he will follow you to the other corner of the room/area.
also regarding this earlier post to which you responded I don't think this is a karnors specific pathing issue, I've hunted in this area many many times and pulled mobs up and down the stairs and never experienced the issues described. The issues I described are all new and similar to the kind of mob under world bugs experienced elsewhere
hmm weird, the text accompanying above image picture was removed when I clicked post the picture above is related to the kedge seahorse under the world (above the roof?) pathing bug described in previous post, it was to help describe the issue a bit better I went to area marked A on the map, which is in the room where Undertow / 'swirlspine seahorse' ph spawns. I got the mob on target, swam under it, cast a spell on it, then swam to spot marked B. The seahorse followed me but was above me in the roof, attacking me but I couldn't attack it back. After a few attempts I swam back to bigger room in area marked A, so it popped out of the ceiling, then when it was on the same z-axis level as me, I swam back to area B to kill. This is a new issue I've never experienced before, and I've done this exact pull around ~20 times before.
three more pulls of Undertow / ph today in Kedge, and can confirm the mob is messed up and disappears into the wall/floor no matter what you try. as soon as you tag the mob, it'll disappear somewhere and start hitting you even if you go right up to the mob on the same z-axis and hit it, it'll vanish instantly and start hitting you from god knows where only way to get it unstuck is to go swim to area B and then area A again
